  • Replies 7.5k
Posted Images
Since the first one is a little high on its milage, though id start a second one.
SPOTTED: MADGT4 on tuesday night showing off how to launch a 4wd with all its fury!! Man your cool, wish i had a 4wd skyline. Too sik for da streets!
mate you can dream of a 4WD car but thats all.hey 2 sik for the steets is copyright now so give me come of your points..he he.. :bonk:
Hey I just had a good idea! (doesn't happen very often)
I'm gonna start a new trend... instead of FULSIK, or SIKREX, or SIKGEM number plates etc... I'm gonna get VOMIT plates. How 'bout these combos? NIZVOMIT, NISPEW, FULBARF, HURLREX, DRYRCH
Dean your plates are so sik that you should keep a bottle of disinfectant in the glovebox... to keep people from getting ill :P Maybe you could get the Royal Adelaide Hospital to sponsor you at Autosalon? :(
Edit: All this whoring has made my punctuation skills go out the window!
Dude don't attack me on the net, you don't know me!
AND how i drive my car is up to me, is it not?
awwa thats so fully sik i had to pick da carrots out
fully off coular bro
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
