  • Replies 7.5k
Posted Images
spotted a grey 4wd (dunno what type but very new n shinly looking) with undercover cops, pull over some1 in town...
also 2day in town at 2pm i was dropping my sister in town and i turned right out of rundle onto pulteney st slowly cos i was tired and then turned left onto north tce 2 head home, and then i look behind me and a undercover cop was flashing his lights...im like here we go...ended up giving me a warning for turning right onto pulteney st from rundle st and going into the left lane from the right lane with out indicating....then went on to say i was going at least 60 in the 50 zone and warned me 2 keep my speed down...cant they find some real bad guys?
Near edwardstown? My Car was unwashed.
I was up there around that time and I did see a pretty tough looking 31 give it a little squirt past me... :(
I was on my way to pick up a few hose bits and pieces as it was going in for a tune at 12:30... Turned out a bit of a bugger as power over 4000rpm would flatten out due to valve float. :D
Spotted Vange on Curry street parked out the front of a pub tonight. :)
wanst at the pub, ended up going 2 crazy horse with 4 of my lesbian friends....lol was very funny haha
the owner of bowdown told me his car was t-boned and yer getting it fixed but would take a while. i would be crying if that was my car
i know how he feels, i got t boned in my old silver 33, it was so bad, they had 2 get a new door..i got the scratches fixed on my rims 4 free! :P lol
Spotted Vange on Rundle Last night around 9 30. You actually parked infront of my girlfriends car (a red integra), and we ended up leaving same time as you too.
lol was having dinner...
spotted white 33, SLY at glenelg, nice rims, looked diff n sounded diff.
I was up there around that time and I did see a pretty tough looking 31 give it a little squirt past me... :)
I was on my way to pick up a few hose bits and pieces as it was going in for a tune at 12:30... Turned out a bit of a bugger as power over 4000rpm would flatten out due to valve float. :P
yeyeye that was me mate :( i thought it was u but looked at ur exhaust and thought hmmm bit too small the tip for a rb30det. baha
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
