....is done is good!
um u mean Don
spotted white GTSt with chick with dark hair driving up modbury last night big ding in rh 1/4 panel
spotted Camry done up to go nascar racing :S
While the new base model Toyota Aurion will still be aimed at families and fleet buyers, Toyota Australia also intends to use the car to spearhead a new push into the world of special vehicles.
Edited by Madaz
  • Replies 7.5k
Posted Images
I noticed a very nice and tidy black R34 GT-t that lives ~30M up the road from us. I've seen it a dozen of so times in the last few weeks. Golden Grove area, black R34 2dr, polished or chromed dished 18's (nice ones not the ugly as hell chrome rims) and a large polished single exhaust tip.
If the owner is on here - nice car mate.
i was behind black r32 today the 1st of march on days rd at the traffic lights at regency and days rd at around 3.15 to 3.30pm, it looked very clean
If it has nismo on the rear windscreen it might've been mine lol? I was down that way on the 1st..
I think what you saw was Munro's old R34GTR Vange - my old man said he saw it belting up Montague Road on Saturday afternoon. He said it came off Bridge Road sideways, kicked the back out a bit more on gear change, then absolutely caned it up Montague Road. Strange for a GTR to go sideways, but I would be he had a torque split controller and had the fronts off.
thats a common miss conception its very easy to get a car with ATTESA sideways
mind u once the computer splits drive to the front wheels it pulls u straight anyways ive never done a long drift in the GTS4 but ive certainly had it sideways arround certain corners i know
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
