  • Replies 7.5k
Posted Images
Went to Marion Shopping Complex for a movie! Saw lots of skylines on the way. Saw one red R33 with a custom number plate - 'DRIFTIN'. Guess what...the car was driven by a woman with a few kids in the car. Unbelievable! :domokun:
On the way back, saw a black R32 stopped by a police on Anzac Highway. Not sure what the guy did wrong thou....... Hope he didn't get DEFECTED....
Saw a nice white 33 GTS-T last night about 11pm on North Easr Rd heading towards town. Had Vic plates which may have been chosen to read from the rear view mirror - execpt they said the wrong model.
i swear.. wherever i go i see that silver r34 with the big crome rims and bomex kit!
spotted on south rd, regency rd, west lakes mall, gouger st.. all within 2 days? very nice car though...
yeh i see that car as well, saw it on hindly last nite near cargo...
ok i didnt believe this but my mates keep telling me that thy have seen my car cruising around, but mine's been in shed for last two weeks. anyways, today i decided to drive it. and what do you know, the 1st 'line i spotted within 10mins of leaving home was a exact copy of mine. damn adelaide is small. *end of conspiracy theory*
haha Duc - you should have kept the stealth spoiler the dodgy fibreglass black it used to be - so we can identify you easier :P .... hey if ever you're passing by my place drop in, as I still have Iceduck's R34 wheel centre caps in my garage - I keep meaning to ring you or something ....
hahaha finaly got it out...yeh i though i saw another 1 like urs in ur area last few nites as i been driving up that way...
whos up 4 a coffee or sweet 2nite/small crusie from meet point to cafe lol?
Yeah moved mine yesterday and did damage to the guard now farken :mrt: Need to raise it...
anyways keep seeing this chick driving a white 33 with black graphics/flame job down the sides, seems pretty decent looking (the chick that is :D)
Cubes... i need to get a triple plate!.... Come to think about it there was a bit of oil lying around the road... It was open wheeling a little bit in a couple of those vids come to think about it!!! So the diff is probably on its way out too!
Anyone know the prices on a gtr V spec rear diff?
Saw an awesome white 32 gtr on parade today... lots of black smoke coming out exhaust (needs a bit of a tune i think! running a bit rich!) Sounded awesome though!!!
Saw Phat34 last night!!! (and man that car is phat -- told me he had over 400+kw at the rear wheels and it sounded like it too (its a pity he had a defect sticker)) Hope to see you rolling one day again soon!!!!!
Perhaps the best 34 i have ever seen!
Has anyone noticed all the symbolism through out Napoleon Dynamite or is that just me? :rofl:
I dont know about a conspiracy but maybe some theory!!!!
Would you like me to teach you guys so you can open your eyes, hopefully this riddle doesnt turn into a shizzle mynizzle fizzle? hehehehe
Have anyone seen V or Davinci code front cover inside and out?
Why a tripple plate. Don't over clutch the car there is simply no need.
A good 9 puk single with a nice flywheel will be fine.
A twin is better though.
Its most likely a standard run of the mill VLSD.
or.. Only you would know this.. Does it run an active LSD as some of the later *don't really know to much about the 33's in this regard* do.
Drive it until it gets too loose then drop a mech lsd in to it with some castrol oil.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
