naw he said the pump is pumping fine
sorry cant be more specific he was talking about it and i wasnt sure if he ment he was gunna look @ it then for the air leak and mentioned regulator but didnt think it was that
he took the AFM off i think the young fella sprayed it and after that it made the 175KW
i got it on camera but its very poor and all you get is mostly sound which distorts over like 4000rpm
  • Replies 7.5k
Posted Images
im fairly sure the stock pump cant handle much more than 175rwkw, thats where mine cut out anyway. i went for the bosch 040 internal, they handle up to 250kw. it made a huge difference, very valuable upgrade that one! :whistling:
ah ok sumthing to look into them whats the cheaper walbro (not sure spellling like the $180 one)
here is link very very poor footage
http://www.youtube.com/watch?v=qPr4_TLD0iY
I got Shaun to put in the Walbro FP and i have had NO issues with mine also.......buth pumps are pretty identical!
my R34 is leaning out in the top end, and I think I would be making a little more power than that - so I think it is true what Sam said. I have just bought a Walbro 255lph pump off Ebay for $125 delivered .... and am going to chuck in a Sard fuel regulator while I'm at it - then get the SAFCII tuned by Donnon, to hopefully make around the 200rwkw mark I am hoping. :whistling:
yeah he didnt push it was possibly leaning out too much or sum other issues i forget
i know after 140kw he wasnt happy about that and knew there should be more in it thats when he took the AFM off and started looking arround @ stuff
i didnt bother getting the dyno chart cause it was incomplete
anyways off to bed got a wedding to drive in tomorrow :whistling:
Edited by Madaz
yeah, I have an 044 in mine, and it's making about 200rwkw (estimate!), I would have thought the skyline setup would streach a bit further than 175?
The cars are getting old.. They pumps are getting lazy. :whistling:
Mine crapped out at around 67,000km's and 160rwkw.
spotted a chick in an orange 32 with front bar in primer coming out of modbury triangle. Also a P plater chick in a maroon r33 down port rush. Looks like most hotties are getting into imports now...
hah the orange 32 is flick from CSA / SHY, luke (skylineguy19) girlfriend............her old car was the black NOT URS lancer..........the car was owned by a chick called erin from NS i believe....
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
