naw he said the pump is pumping fine
sorry cant be more specific he was talking about it and i wasnt sure if he ment he was gunna look @ it then for the air leak and mentioned regulator but didnt think it was that
he took the AFM off i think the young fella sprayed it and after that it made the 175KW
i got it on camera but its very poor and all you get is mostly sound which distorts over like 4000rpm
  • Replies 7.5k
Posted Images
im fairly sure the stock pump cant handle much more than 175rwkw, thats where mine cut out anyway. i went for the bosch 040 internal, they handle up to 250kw. it made a huge difference, very valuable upgrade that one! :whistling:
ah ok sumthing to look into them whats the cheaper walbro (not sure spellling like the $180 one)
here is link very very poor footage
http://www.youtube.com/watch?v=qPr4_TLD0iY
I got Shaun to put in the Walbro FP and i have had NO issues with mine also.......buth pumps are pretty identical!
my R34 is leaning out in the top end, and I think I would be making a little more power than that - so I think it is true what Sam said. I have just bought a Walbro 255lph pump off Ebay for $125 delivered .... and am going to chuck in a Sard fuel regulator while I'm at it - then get the SAFCII tuned by Donnon, to hopefully make around the 200rwkw mark I am hoping. :whistling:
yeah he didnt push it was possibly leaning out too much or sum other issues i forget
i know after 140kw he wasnt happy about that and knew there should be more in it thats when he took the AFM off and started looking arround @ stuff
i didnt bother getting the dyno chart cause it was incomplete
anyways off to bed got a wedding to drive in tomorrow :whistling:
Edited by Madaz
yeah, I have an 044 in mine, and it's making about 200rwkw (estimate!), I would have thought the skyline setup would streach a bit further than 175?
The cars are getting old.. They pumps are getting lazy. :whistling:
Mine crapped out at around 67,000km's and 160rwkw.
spotted a chick in an orange 32 with front bar in primer coming out of modbury triangle. Also a P plater chick in a maroon r33 down port rush. Looks like most hotties are getting into imports now...
hah the orange 32 is flick from CSA / SHY, luke (skylineguy19) girlfriend............her old car was the black NOT URS lancer..........the car was owned by a chick called erin from NS i believe....
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
