  • Replies 7.5k
Posted Images
R33 Greenish (seemed to be fading) GTR (badge on front) with a space saver wheel on the back left rear. Down the bay :D Also Gunmetal grey/black R32 headed towards bay with slight kit and possibly 17" rims at 5:50pm.
Saw a black 33 on my way to work with plate BLKSKY i do believe! Nice and clean ride there!
Yup....That was me! Hahaha...First time being spotted after having my baby for more than a year. :sorcerer: To be honest, I was a bit annoyed this morning - some uni sh*t..., but didn't realise that being spotted by someone would have brighten up my day by so much!...Lol...Feeling much better now! (probably because the only think in my mind now is my LINE ... Nothing else! )
Vange probably won't be able to comprehend such feeling anymore since he's being spotted nearly everyday!! Lol :(:) (jk)
Edited by bixby
Vange probably won't be able to comprehend such feeling anymore since he's being spotted nearly everyday!! Lol >_<:D (jk)
Glad i could make your day better....... to be honest i think i spotted you about a week on Gouger St also!
yeah Ash havent seen you for ages even though I live and work here your work place. maybe if you switch back mufflers, I can spot you out alot quicker but that defeats the purpose in the first place doesn it? hehe
spotted silver r33 gtr pretty sure it was a gtr today at marion shopping centre just near bunnings approx about 12.30 - 1.30 also spotted a couple of 33's in the castle plaza carpark one dark green one with 5 spoke star shaped rims, and a dark grey/blackish 33 parked along the shopping centre front, also at bunnings saw a white mr30 sedan with some weird spoiler
Saw deluxes car parked down at bay on sunday..looks tough champ!
Saw grey R32 going for a strap at windy point on sunday arvo as well, then tuesday night going out for tea saw a black Stagea wagon on R34 GTR wheels pulling into a street just around the corner from my house...YUM!!!! :blink:
...then tuesday night going out for tea saw a black Stagea wagon on R34 GTR wheels pulling into a street just around the corner from my house...YUM!!!! :rant:
from memory that stags owner is on these boards he has a 32GTR also
I rekon that could have been me spotted in the stagea boof, and you were pretty close Madaz, the 32 is sadly only a GTS-T under all that fibreglass...lol.
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
