  • Replies 7.5k
Posted Images
saw dark blue 4door 33 with gold rims on sturt rd near marion bout lunch time, if that was anyone on here not bad ride i was in the white 33 infront of u!!
Edited by siba33
Just spotted a Black Stagea with twin mufflers(ET job i would say) and 34 GTR wheels, looked really nice, could do with a bit of a lowering but other than that, nice as! Oh yeh was at HJ's on West Tce
That was me Deluxe, grabbing a quick bite to eat while running around looking at motor bikes for a friend. Close on the exhaust, but was done at everlast, the guys up there have done many a system for me and look after me really well! Im working on getting it closer to the ground, lookin to chuck in some coil overs soon, just got to save up some cash......damn mortgage......
Deluxe:
I think thats GRIMS on here. Has an R32 thats black and modified like theres no tomorrow.
Im pretty sure its an RS260.
Pure GOD
Good memory R32_4door, correct on accounts and cheers for the compliment! ;)
Yeh nice mate..... she did look sweet as!
Also saw R32_4door this morning at lights on Richmond and Marion Rds, gave you the wave, pretty sure you saw it!
Good memory R32_4door, correct on accounts and cheers for the compliment! :pirate:
Daryl and Justin are top blokes i couldnt speak more highly of a buisness and Cubes if u see this and they arent in the Buisness list please add them www.everlastmufflers.com.au ive been using there services for the last 15 years i recon since i was about 18yrs old now 32 you do the math cause i fail @ maths
i built Justin's PC and did work on his other 1 @ discounted prices for all the time when you go in there and say oh ive heard this and wot not and they spend like 30 mins with u looking @ stuff and never charge you
when i bought my R33 Jim Nadler was still there and he did like a quick x point check on it and even took it for a test drive and gave it two thumbs up
anywhoo would recomend any1 to use EverLast Mufflers
Saw a White R33, most likely Vange but i couldn't swear to it your honour, turning in to Hindley St @ ~6:30AM yesterday. :)
lol nah wasnt me, i need my sleep! haha
sorry whiplash, i thought u were the s14! lol
Edited by vange
everlast mufflers, which location/suburb is this as im thinking bout changing my exhaust tip.
there @ modbury on golden grove rd 2 mins walk from the hungry jacks on the corner
EverLast Mufflers
31 Golden Grove Road, Ridgehaven SA 5097
Ph: (08) 8396 3255
tell justin steve says hello and to use his computer :) and i will try to drop in soon :)
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
