too much! haha, I think around the $16.5-17k mark. Low km's though, and clean car!
Yeah, it was driven on weekends only as I caught the train to work. When I bought it it had only done 26,000Kms and sold it at 60,000Kms. 34,000Kms in 5.5 years...!
Well, hope your mate enjoys it as much as I did!
  • Replies 7.5k
Posted Images
Yesterday spotted a red LAMBOGHINI DIABLO on NE road Modbury.
Thing was hawt plates were red but I couldn't see the name, made me swerve across the road trying to check it out
Edited by Tuffr32
Spotted my first R34 GT-R today on West Lakes Blvd about 4pm. Gunmetal, no wing, Victorian plates BEA something or other.
Cruised past and gave him the thumbs up! Need to see more of these out!
spotted a grey skyline crashed in the bushes this mornin on churchill road... hopefully nobody from sau! there wasn't anyone there with the car except for a couple of cops...
i was goin to post that as well earlier on, but only remembered it just now
that car was fair f**ked up, straight away i was hopin it wasnt anyone from here
It was a Countach - I spotted it down near Windsor Gardens. Has LAMBO-1 on the plates.
Yeah it was a countach, knew it was one of the old skool lambos
Had a look at the specs the late models have a 5.2L V12 run 0-100 in 4.9 secs, but look like a giant remote controlled toy car :(
eyy i kinda slowed down & waited for u to catch up to suss ur car out, whether its a genuine GTR or not :(
still waiting for my personalised SA plate to come
likewise, would love to cruise with the original 'Godzilla'
Edited by andz69
Saw someone looks like MIB drove a new Rolls Royce (Phantom) in the city on Satarday around 1pm, very, very nice car and that's over AUD $1,000,000. Did anyone see that car before?
Details as below:
-Engine Twelve cylinders, 60 degree V-formation, chain-driven DOHC per bank, four valves per cylinder, electronic valve timing control, all alloy.
-Power & torque 338kW @ 5350rpm KW 720Nm @ 3500rpm
-Transmission 6 speed Automatic
-Fuel 100 Fuel tank capacity (litres)
Saw a black one cruising the bay once but, that was over a year ago. I heard when brand new these are the fastest depreciating cars ever...something like $400 a day :P
    • Which model Maxima? This is good knowledge to have.
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
