[SA Cars Spotted Thread 2]
N/A®
 Share
Hey I just had a good idea! (doesn't happen very often)
I'm gonna start a new trend... instead of FULSIK, or SIKREX, or SIKGEM number plates etc... I'm gonna get VOMIT plates. How 'bout these combos? NIZVOMIT, NISPEW, FULBARF, HURLREX, DRYRCH
Saw a statesman last year with number plate PUKE, thought it was hilarious!
  • Replies 7.5k
Posted Images
Spotted white r33 maybe series 2 on anzac hwy parked into a bus stop with a harley on the ground next to it hope not anyone from here.
Was going to comment on this but wasn't near computer. No offence, but whoever the driver of that white skyline is better get a hiding from whoever can give it to them. They were being an idiot on the road infront of us drifting, then lost control, hit the gutter, bounced acrossed the road, hit the guy on the bike and then into the bus stop (had R33 GTR rims and wing, not much left on the front to tell if it was a GTR i.e. drifting GTR?? - being mangled in the bus stop). At the same time my mate in his wrx almost got cleaned up while he was 'drifting'
If anything I hope the guy who didn't seem to move much on the ground that was clean hit off the bike is alright, we sat across from the crash in the big carpark close to Macca's. People like this should learn and not give skylines a bad name! I can only imagine what cops will be like now for the next month on skyline owners.
Hope both are alright.
Dan :laugh:
Edited by DC_GTST
^^ just came on here to make a comment about this aswell. looked like it had just happened when me and my partner drove past and we were wondering if it might have had something to do with silly behaviour on the skyline drivers part. drifting on anzac highway isnt the smartest thing to do.... hes lucky he didnt take out anyone else..
anyway i hope everyone involved is ok nonetheless.
ah crap must be the night for crashes went on a Cruising SA cruise and a dude in a s14 stacked due to brake fade pretty much wrote his car off .. i just dunno why he didnt slow down once he knew brakes were spongy
spotted Hostile heading into the city @ about 10pm on anzac hwy
Thats not always possible Madaz.
When I was young and Silly in my VS Commodore 5speed v8 I ran bendix metal kings. Before I knew how poor the metal kings really were I punched it hard up to around 100km/h then braked hard to ~30km/h, then again up to around 100km/h then hard down to ~30km/h.
The brakes still felt perfectly fine. the next corner I went to hit the brakes at around 130km/h and I had literally nothing.
Straight back to second for a diff lock, then ripped the handbrake on and slide to a stop almost collecting a guard rail. There was no time to 'try' and stop it, I thought I was going to hit the guard rail, I simply tried to shed off enough speed to minimize the impact. I was just lucky.
I then fitted Bendix Ultimates and no more brake fade.
Dan :D
I was with you'se in that carpark, black GTS-t with front end prang. What car were you in?
That was a horrible crash by the way, and hope all are ok.
But, that was one of the stupidest, most reckless thing I have ever seen, and I hope owner of the white 33 gets what he deserves and seriously learns his lesson.
This type of crap gives all imports and clubs a bad name.
Dunno if its the same White R33 I saw up at Kings road parafeild last week. While I was playing tennis he jst ripped a few drifts in the parking lot, not good considering its next to a tennis court and across from a swimming pool centre full of kids :D
On a lighter note spotted a PHAT black cefiro at Z imports 2day with full Uras kit, flared guards etc
i believe i know of this 33 everyone is bagging but dont be so judgemental because there is probly more to the story than just what everyone has seen/ heard.
Keep seeing a purple 33gtr coming down or going up past the gully hotel!
spotted a black 33 with a sau sticker on rear window with cc plates on rowells rd lockleys around 4
also saw couple of lines on jetty rd glenelg DRIFTN (i think its right) and V8EATER (again i think thats right 2)
that sounds like my 33 mate :)
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
