[SA Cars Spotted Thread 2]
N/A®
 Share
Spotted a pair of 33s leaving TTP near HJs chatting at the lights
one wine red with aftermarket front bar and the other white, I was driving in the other direction so couldn't see plates, to busy watching the road like a pirate :(
  • Replies 7.5k
Posted Images
Hey leeman, yeah i do live in olive grove, cant say ive seen your 34 down there tho, or are you normally in another car?
There does seem to be a few sau members down this way, we should organise to catch up some time, would be good to put some faces to names!
+ 1 for living in olive grove as well!
And can't say i've seen leemans 34 around either, seen Ben's stageas around though!
Spotted thursday night on way home going over the overpass of port wakefeild road down south road extension was a wine red R33 with some kinda dishy rims really didn't get that good of a look at it though!
Spotted Leeman by Blockbuster at Munno Para Saturday arvo about 6:30ish.
I was in the little blue Swift, gave ya a bit of a head nod. Not sure if ya recognized me or just thought huh :laugh:
No i definately didn't recognise you, should of said something. Would of been good to have a chat! For the next ten minutes i was thinking who do i know that drives a little blue car!
Hot-purplish colour R33 GTS-T at BP on West Tce, it was something different & looked to be a chicks car. Had rear eyelids to make the hot plates look similar to the R34's & the front plastic covering the front lights was removed.
Parked next to PK BLADE at pizza house west tce, freindly wave at him before I ran out to order pizza n ran off to fill up petrol b4 pickup :P
Was wondering whether you were someone from the forums, nice ride. Mate & I were waiting for a small convoy of cars to go for a cruise.
Whilst leading the cruise at Outer Harbor & taking them around the carousel several times :laughing-smiley-014: spotted a nice silver R33 passing through.
almost thought i spotted madaz on fri nite turnin from east tce onto port road (down by ice arena)..............exact same colour 33, similar rims, same kit, just a coupe instead of sedan...............dude waved back anyway
just then spotted someone in a black 33 tear down my street and skid to a halt 50 metres down the road to avoiding cleaning a couple kids up.
if its anyone here, hand in your car and catch the f**king bus!
that f*kn pisses me off something cronic.
time and a place arsehole
Edited by Ryanrb25
This morning in Holden Hill a silver R33 with a very low front bar, gave a nod but I think only got a blank stare :). Then around the corner on Grand Junction a black R34 GT-T, thought it Nightcrawler but it had the rear wing on & driver was late middle aged.
7-30 / 8am this mornin, headin south on tapleys hill road from roughly trimmer pde till henley beach rd..........DVS-R34. Clean as, tuff rims dude (if ya on here). Was in the piece of snot ETSA truck one back in the left lane
spotted a chick driving a silver 33 gtst near my work then another older woman driving a silver/grey 33 4 door and a black 33 just behind her with no rear wing
saw a nice Sx*-180 this afternoon also
Edited by Madaz
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
