  • Replies 7.5k
Posted Images
spotted a very lucky asian tonight in a bayside blue R34 GTR @ magil gave a nod got a nod and wave back
also earlier spotted a black 32 GTS4 with number plates like that GTS-4 or something red back on white letters anyone here
spotted a nice white 32 i think in the way up sheppards hill rd going over goodwood rd
Spotted White R33 Series 2 with some form of pink writing on the bonnet (chick driver) on Marion road, right onto Cross roads (i headed straight) - nice clean car. Spotted silver R33 S1 & 2 down anzacs also.
pulled up next to a black 33 on west terrace this evening bout 6:30ish. Looked familiar, didnt get to see plates, but think it may have been the 33 with the plates 'blk sky' or similar, know hes on here just cant remember user name.
Not sure if ya seen me give ya a quick wave as i took off
Also, not a spotted by me, but my boss at work spotted some little thugs on holidays trying to steal my valve caps and then testing my doors, he gave em a good scare, hopefully they wont come back.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
