[SA Cars Spotted Thread 2]
N/A®
 Share
this was a week ago now but after seeing some sau boys out at the drift day, i remember seeing brenton(32 4 whore) car down at cafe de villes the new freedom..lol dude i luv ya car.. always had a real soft spot for a clean 32 4dr. and keep up the good work on the track :D
  • Replies 7.5k
Posted Images
Saw SLIK33, may have had a space between the K and the 33, don't know. Plates were on a Red R33 GTS-t on Grote street near Vic. Square in the city today at 3.50.
Seen a black R33 GTS with black plates; FADIE heading away from the city up Goodwood Road on Tuesday around 4.45 pm and again today, going up south road just before you get to the Mitsubishi plant, also heading away from the city, cant remember the time tho, around 12 I think. Nice looking car.
Yeah thats my bros car, his username on here is FADIE too.
Jap import at the start of this year, looks of work to do on it, should be a bit of fun soon :(
Nah Darren, would have been the face I was in a Daihatsu Applause :laugh:
Not a worry Andrew, as I said, you wouldn't have recognised the car anyways :(
Edited by heslo
Spotted a few SAU skylines lately
Saw madaz cruising along hancock rd I was on the side of the road, didn't wave cos I would've looked like a weirdo
Saw a silver 2dr 33 out near boostworx with SAU stickers maybe Adz, looked like his pic
and a red 32 with white rims also near boostworx
- Nightcrawler Im still keen on that turbo will let you know soon
lol who says i dont wave to weirdo's :sleep: good call probably
I think you just spotted me bud, you are the first one, I go to Panorama TAFE there on Mondays...
I've had the car for that long and your the first one, I'm truly amazed.
Ah yep, thats the one. He must not be on here very often.
Spotted [CELTS 5] (think thats it) again on sunday, was in the noarlunga cinema carpark, was around 3.10pm, was gone by 4.40pm. Dont think the owner is on here tho. Anyone know the owner of the maroon/pinky looking R33gts-t with [HADDAD] on the plates?. Used to work in colonnades some place i think..
Was that your first time? Hi Faive
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
