i was more there around 8:30ish, going past sipnsave.
yes dean. it was most likely me.
Yeah it prob was more like 8:30, was sitting in Cafe Bravo and you pulled out of one of the side streets onto the parade....nice ride!
  • Replies 7.5k
Posted Images
if u mean nice by, it was clean cause i cleaned it that day, and, it sounds good, or, it goes fast, then thanks.
i have stock 16's on it, no body kit, a front mount and an CAI in the left side of my front bar...
Spotted a nice white 34 heading south on kingwilliam in the city this morning at bout 9 am. May have been the one from the autofest photos next to flick's car?
Then on belair rd where i was working a black 33, silver 32 and a white 32 all heading towards the city at various times
If it was round lunch time when you saw the black 33 that would have most likely been me >_<
Saw olds32 at the goodwood rd and daws road intersection and saw SKY095 a very nice 4 door 33 on rundle street on the way to work
I tried waving if you saw me, we were pruning a hedge on the side of road!
Also spotted VANGE MOBILE today as he was enjoying the beautiful scene at the torrens river with someone special.... :/ That probably explains why the "VANGE MOBILE SPOTTED THREAD" has been significantly reduced lately... :/ lol Just kidding mate.. It's good to see ya around.
hahahahaha........dont worry i wont get 2 that stage!
still no spots an i cruised hindly an rundel last nite, might need to ask vange how he dose it. also had jap plates on an didnt get a look even from the boys in blue
ppl r just out 2 c me...thats y lol
2 skyline owners in the same area ( prospect/blair athol boundary )
one in my street and one the next street over - if ya on this site ill say hi
black r33 coupe with bbs type rims, the owner lives near a round-a-bout
the other
blue or black r33 sedan , nice exhaust
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
