[SA Cars Spotted Thread 2]
N/A®
 Share
spotted a r32 with veilside c-1 kit at marcellina's near bunnings on mcintyre rd (i think thats the rd) had a orange colour (similar to flick's car -- i thought it was flicks car until i looked at the front bar a little closer!)
  • Replies 7.5k
Posted Images
another orange 32?!
:woot::D
Haha yeah probably was mine...considering it sits there all day!!! :action-smiley-069:
Yeah i got fuel there after leaving morpowa, i assumed u worked there but u musn't have served me
spotted a white S2 33 with black dished rims last night in the city. Think it was still stock b/kit but it looked tough.
that would have been me if it has a stealth spoiler and slighly lowered with tinted windows.
Spotted a black R32 Lowered with R34GTT wheels on Winston Ave yesterday morning.
Also spotted maroon 33 Tuesday evening, driving next to him on my way home up goodwood rd/five ash drive.
Spotted MISS 33 on West Terrace yesterday at about 6pm..... Hot ride with hot chick! :)
Also saw a midnight purple R33 GTR parked at John St. yesterday with NSW number plates. Looks tuff!
Spotted DRIV3R today on Goodwood Rd at about 2:45PM parked on the side of the road, I tooted but I don't think you knew wtf was going on, was in the missus mobile
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
