  • Replies 7.5k
Posted Images
spotted jas033 at her work today around 12ish, love the colour!
Spotted your to!!! Did you come in?? I was in my own world and seeing i never met you I wouldnt reconise you anyway lol. I seen your car driving out.
i think i spotted Oosh this afternoon @ st agnes driving towards the plaza shortly after i saw the Blue 33
i really need to get my horn fixed on my steering wheel all the plastic has broken on the inside of that part
heslo, seriously dude, you must barely be awake in the morning - I've seen both you and your gf go past me in the opposite direction on my way to work, and still no mention!! I've put new plates on for you to work out what it is a little easier :O
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
