[SA Cars Spotted Thread 2]
N/A®
 Share
  • Replies 7.5k
Posted Images
spotted luke (fishpaste) driving the gtr past mine last nite, and again today
yep, thats the new daily u seen me climbing into in the drive :D
i spotted all the comotion at your place last night and wondered if you had returned and i guess i know that your back now!! =P i'll have to have a better look at the new daily sometime, was it the same one you were loking at before you went away??
how was the trip?
Hey PK
yeah that was me - where were you??? i was going done to see simon at dzignfx (the guys that did my nismo decals)
Was at the lights on South Rd & my car was on a flatbed.
Went for a quick run down Anzacs to town and back to Bay. Seen a silver 200sx (s14), black R32 GT-r and Troy in his WRX turning onto West Terrace. Then spotted two R33's next to each other headed towards bay along Anzacs, and Maroon R32 gts-t on way on West Terrace again
Also spotted Vange on East Terrace :D
That mighta been me in the maroon 32, was there a black 300zx ahead of it?
spotted a grey stagea turning right off glyndburn rd onto magill rd, "MR R34" on north terrace, and a grey R32 GTR near rostrevor college all yesterday
Spotted Fishpaste down hindley around 1:30ish last nite, nice ride mate :laugh:
right back at you! when did you get the GTR? i thought you had an rb30 GTS4? yeah, not sure where you headed off to, but i was meeting a few friends at the blue and white for a late night AB =)
spotted TANGLES ( i think at marion) don't know how many other white stageas have 34 rims on
the wagon was looking mighty fine as always :D
Edited by Whiplash
how was the trip?
friday night commotion? nah, thats a usual friday night at mine (with exception to one car, which was my friend's lancer - she dropped me home from the airport)
feel free to pop round, that was the ute i looked at before i went away :D plus the 31 is back lowered again THANK GOD
Spotted a nice crunched WRX Sit (2003-5 model?). Just after intersection of Marion and Oaklands - on the S-curve. Spun around (obviously going bloody quick) and lost control - spun backwards into stobey pole. Whoever was inside were extremely lucky, given that the whole entire back and part back right was gone. Hope all alright though
^^^ Doh! missed it but, have seen the segment you're talking about. I luv the styling on the P2 & it has some pretty cool hi-tech systems on board. Also, would be awesome if it did go into production.
who spotted top gear tonight with that little subaroo whoa that is awesome made Jeromy sick ;)
I guess you could say that car was Sick! Was a good show as always, definately my favourite tv show
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
