[SA Cars Spotted Thread 2]
N/A®
 Share
  • Replies 7.5k
Posted Images
Spotted a white R32 at modbury next to the stairs near the underground carpark by woolies. Had a front mount, sunroof and the most important thing, an SAU sticker in the back quarter window.
Parked next to you because I knew I wouldn't end up with a door opening into the car.LOL
Yeah thats me :D you must have left before me, I would've noticed a skyline next to me
doing some shopping for the hot weather coming
Spotted a SHIT HOT red Mitsubishi FTO labelled with stickers all over its drivers side passenger area... gave driver nod
also saw a dark blue (or purple) R33 (think it was a gtr) on goodwood road. Followed it from cross road intersection to south road city,
saw a very nice bright yellow 180sx being transported on the back of a flatbed for a crash repairer. Looked bloody awesome. Again goodwood road, cross road intersection.
-D
spotted Mr ISC-Performance, i was the random in a camry tooting and waving.... soz =(
was hoping you were gonna keep heading along marion road so i could chat with ya, your store around where you were doing the u-turn? =D
Edited by Fishpaste~
was hoping you were gonna keep heading along marion road so i could chat with ya, but just tooted and waved =D
haha...I was wondering who that was I was going to flip you the bird.. :D Store is next RD over. Adress is below in Signiture.
Ryan :laughing-smiley-014:
spotted sinista on magill road this arvo a bit before 4. was headin the other way (i waved but then once again realised im driving a commodore LOL). ya had a white 34 not far behind ya..................either it was u or theres another body double of your car, silver mirrors and all LOL
spotted a dick load of skylines at lofty's tonight, i was driving a mates pimp celcior, the 33 was chillaxin...nice turnout of skylines especially GTR's.
also spotted a few skylines having a chin wag at super cheaps at near coca-cola.
Edited by Ryanrb25
 Share
    • After I unplug maf car dies, won’t start. Same with iacv valve - two connectors mounted behind manifold
    • here’s link to photos bcs can’t add it here blue spots - I can install recirc valve hose there and in general everything air intake related so you can spot of anything wrong here
    • Sorry for late answer but here’s my spec: Series 1 1994 r33 gts25t AT converted to MT using r32 rb20det gearbox. Custom self made clutch pedal os giken twin plate clutch two pins connected to let engine start speedsensor from AT connected to wire harness but didn’t fit to gearbox So it’s somewhere inside in the car so I can add km to tachometer after I measure distance with gps. Don’t want to pay 150€ for sensor if I probably will change gearbox with adapter to bmw one. Car barely runs and winter is coming so no point right now  engine after rebuild Stock automatic ecu and at tachometer Aftermarket oil cooler with separate sensor so oem oil pressure is unplugged  koyo 53mil radiator  Mods which may cause the issue: 600x300x76 front mount intercooler Cone air filter blitz Removed recirculating valve Slighty bigger maxspeedingrods turbo adjustable manual boost controller (didn’t set it but last time I checked on aftermarket gauge it was 0.4bar, asaik oem is different unit 7(unit) don’t want to rev it too high bcs it made max 70km after rebuild Fuel pressure regulator set to idk 30-32psi at iddle dw300 fuel pump stock injectors check valve right in front of fuel rail i thinking sth wrong with afr it getting too much fuel and too less air or it needs that recirc valve? on warm engine it took 5-10 seconds to start it. After I put way bigger battery, battery terminals and new ecu coolant temp sensor problem is gone my old turbo spill 150ml oil into intake so cleaned it.    I checked for error codes and it given me 55 - all good. I bought consult so will plug in soon to check if it give me better feedback. Also I will install oem recirc valve tomorrow. Small hose going to manifold but where should go 30mm pipe from this valve? I’m front of turbo inlet, after maf/ right after turbo outlet / or it doesn’t matter? actaully can install it in these two spots (blue circles)
    • I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
