  • Replies 7.5k
Posted Images
I wouldn't be so fast to make a blanket statement that all 19's are crap. If you have a look at alot of the euro and japanese touring cars running massively large aluminium rims.
But I see your point, alot cars these days run 19's for the bling factor. Which is okay I guess if it's just a cruiser.
On another note... knickers?? :(
I doubt many can afford one 19' aliminium not to mention a set. 19's make handling really crap, I mean with my 18's its on the nerve of giving me the sh!ts. I dont think they contact the road as good as 17's or 16's would. I might be wrong but alot of people - general public that is, not talking workshop cars, use 16's predominately or 17's when running down the strip.
Anyone seen or know of a dark blue rx8 with a very very low bodykit (Wise sport type) going around Adelaide sporting trade plates. Apprently it has force induction of some short.
that would be nice the Rx8 has 186KW NA which would = arround 150RWKW not to bad for a 1375kg car
Yeah looking at your avatar just reminded me of it. Was on main north rd going towards town when i was heading home. Just heard a loud bov flutter and it went pass. Also heard a bov flutter from a civic sedan on the parade. I wonder how they would go being fwd and all.
nice Madaz - thx for the artwork. I was going to do it, but now you saved me the trouble :(
Yeah I have seen a Silver 350Z with some sort of turbo setup too - big intercooler in the front gives it away!
Has anyone here actually driven either a 350z or rx8 (some ppl on this forum says the mazda 3 turbs are better). Opinions besides the looks - exterior and interior.
yeah ive test driven the Rx8 very nice 6spd manual leather int. 18" rims was very comfortable yet had the feel of sporty wanna get up an keep going
yep I looked at buying both a 350Z or an RX8, and drove both a few times. Both very nice - handling fantastic, awesome leather interiors, lots of toys etc etc. However both were quite underpowered with very limited ability to modify - plus were going to be a $30k+ changeover from my S15 (which in a lot of ways is a better car) :(
I heard of a fairly low km RX8 selling in the Eastern states for $36k the other week - so am damn glad I didn't take the plunge now!
Gosh $36k and not even an 'import'. Im thinking a VQ would be on par with a N/A rb25 if not better due to its higher displacement. No doubt the interior of the 350z are awesome, just curious as to how good it would be in stock form - say the track spec one's. Never driven a car at the showroom's before, is there alot involved before they let you give one a go I wonder..
just drop in in your line and have a chate if your serious they dont even care if your not
i wasnt gunna buy a Rx8 just wanted to drive 1 :( i was on the priority list for when they first came to adelaide cause i signed up @ the mazda site
sp[otted this http://www.carltonaudiovisual.com.au/?q=node/view/475 :) verry nice monitor/tv
Edited by Madaz
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
