  • Replies 7.5k
Posted Images
where can you test drive an R34GTR Duc?
when you ask politely. andy's gtr34 was taken for a test drive after we fitted his newly acquired exhaust and it goes fast!! bugalugs and i got to drive it :teehee: cheers andy
hey my gunmetal grey r32 was stolen yesterday from mawson lakes...it's got black and gold plates that say MISS 32 and a mass gold playboy sticker on the back window, its pretty noticeable...if anyone sees it please let me know...or the police...should be 3 feral blokes in it it's probably in the elizabeth/salisbury area..
Hey I'm guessing you got your car back? Because I saw it parked in a street in Mawson Lakes tonight. Either that or the crooks who stole it have parked it nicely out the front of someones house haha
wouldn't happen to know the street would you because i haven't got it back yet...
Spotted a white R33 on Gorge Rd today with an unpainted front bar, he gave me a little wave, anyone from SAU?
yep that would be me :( car has diffrent rims and front bar from the pic in my avater now tho
Edited by iLEC
spotted a fellow sau'ers silver r34 in sinery's car yard. its the one with black spoked impul rims. what did you trade it in for mate? i remember seeing it a while back at a sau midnight run to the hills.
Guest
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
