[SA Cars Spotted Thread 2]
N/A®
 Share
  • Replies 7.5k
Posted Images
Spotted (running alongside) a Silver S2 R33 with VIC plates and no wing this avo along Port Rush Rd.
Also this morning a maroon R32 with black boot lid turning from Black Rd onto South Rd at O'hallarin Hill
Edited by Hotwire
Spotted nice looking Silver R33 SII (fmic, lowered, drift spoiler) turning right onto south road from torrens road this morning, thought I noticed an SAU sticker on the side but not sure.
Bloody hell Steve, never saw a pic, he's lucky to be alive...
On a more positive note, spotted DNW on South Rd/Majors Rd intersection, HOT chick driving it, VERY NICE :unsure:
yeah thats in our yard, cant believe they surrived. hope you's have recovered well
Hey Steve i will try and come down there tomorrow or next week to speak with you about some brake upgrades for the NA version R33
spotted 2 door 33 P plater just near tyresplus on my way home just before
as for recovering i dont think some peoples have there are a couple of lads that dont come here any more me i thank God that it wasnt me that hit the festiva
spotted 2 silver 33 coupes coming off holbrooks rd on to henly beach, only caught a glance at them but it looked sweet with both of them tailing each other up the road... and a blood orange/ possible red 33 coupe parked at a thai take away place on grange rd.. think it was NA :)
yeh mike, cheers......u got new wheels too? or has it been a while since i seen ya 33? looks tuff none the less
nisswreck - i think i remember that 33................its been a long time since last week lol
Guest
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
