[SA Cars Spotted Thread 2]
N/A®
 Share
  • Replies 7.5k
Posted Images
yep patrick, saw you there too, was at trade school, still am :( as you can see im so bored that im forced to surf the web on my phone :action-smiley-069: your car looked tough as!
spotted jas033 at her work today around 12ish, love the colour!
Spotted your to!!! Did you come in?? I was in my own world and seeing i never met you I wouldnt reconise you anyway lol. I seen your car driving out.
i think i spotted Oosh this afternoon @ st agnes driving towards the plaza shortly after i saw the Blue 33
i really need to get my horn fixed on my steering wheel all the plastic has broken on the inside of that part
Yeah Jasmin, I did drop in, bought a pack of chewies, I think it was you that served me but wasn't 100% (didn't have a name badge) You a blondie?
yeah that was me :laughing-smiley-014: was in exquisite audio and visual talking about a 12" sub and amp...gonna get a "package" from them just gotta start saving now!!!!
heslo, seriously dude, you must barely be awake in the morning - I've seen both you and your gf go past me in the opposite direction on my way to work, and still no mention!! I've put new plates on for you to work out what it is a little easier :O
Guest
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
