  • Replies 7.5k
Posted Images
spotted luke (fishpaste) driving the gtr past mine last nite, and again today
yep, thats the new daily u seen me climbing into in the drive :D
i spotted all the comotion at your place last night and wondered if you had returned and i guess i know that your back now!! =P i'll have to have a better look at the new daily sometime, was it the same one you were loking at before you went away??
how was the trip?
Went for a quick run down Anzacs to town and back to Bay. Seen a silver 200sx (s14), black R32 GT-r and Troy in his WRX turning onto West Terrace. Then spotted two R33's next to each other headed towards bay along Anzacs, and Maroon R32 gts-t on way on West Terrace again
Also spotted Vange on East Terrace :D
That mighta been me in the maroon 32, was there a black 300zx ahead of it?
Spotted Fishpaste down hindley around 1:30ish last nite, nice ride mate :laugh:
right back at you! when did you get the GTR? i thought you had an rb30 GTS4? yeah, not sure where you headed off to, but i was meeting a few friends at the blue and white for a late night AB =)
how was the trip?
friday night commotion? nah, thats a usual friday night at mine (with exception to one car, which was my friend's lancer - she dropped me home from the airport)
feel free to pop round, that was the ute i looked at before i went away :D plus the 31 is back lowered again THANK GOD
Spotted a nice crunched WRX Sit (2003-5 model?). Just after intersection of Marion and Oaklands - on the S-curve. Spun around (obviously going bloody quick) and lost control - spun backwards into stobey pole. Whoever was inside were extremely lucky, given that the whole entire back and part back right was gone. Hope all alright though
Guest
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
