At boostworx this avo spotted Sambo's car looking a little out of breath (no turbo ;) ) a grey R33 S1 plates Blitz, Alan's 31 coupe, and one other white S1 leaving just after I pulled up.
Boostworx=Skyline central ;)
hehe, my cars a non-turbo :)
im going to go pick it up tonight, cant wait to drive it again!
  • Replies 7.5k
Posted Images
spotted sambo's car out front of boostworx this arvo when i called past to see shaun
also just spotted bezender before cruisin along seacombe road. yeah that was me that tooted and waved from the red ute as i was waiting to turn out of my street
spotted hotwire the sarvo on port rush near the parade, was in the mrs rex commin out of the parade you looked at me lol
Nope, wasn't me Dan...
I presume you meant servo, but either way my car was at Boostworx all day (clutchless) untill 7pm when troy finally finished it and I drove it home tonight with my new xtreme HD :P
Spotted MIS R33 at the Woodcroft shopping centre this afternoon. Nice car.
And at about 6pm I spotted myself in the rear view mirror driving my skyline for the first time since May 12. YAY!!!! *balloons & party poppers*
Now I just have to get 500km into the newly rebuilt engine.
Shit nah the skyline i spotted waas identical to yours then rims kit everything, and was at the intersection on portrush rd and the parade heading towards the freeway lol, and nice to see with the clutch mate.
spotted a black r33, white r32 4 door, black r32 and a blue r32
spotted about 8 r32's on the way home tonight mainly gunmetal grey and silver.........there was a black one tho........also spotted one black r33
I didnt think this thread was a competition to count the most skylines!
Try to post more about the car you see, or where you spotted it, so ppl can know if it was their beast or not.
Lucky its not a commowhore thread or you'd lose count.... 88 VS's, 42 VT's, 19 VX's, 15 VE's...
spotted an amazing bayside blue r34 gtr "v sp 034" had vic plates on.....caught up and got a nice little smile from the driver :spank:, also spotted a silver r32 gtr on mcintyre rd this morning, "r32gtr" got a wave, waved back of course!!!!!
also spotted (cant remeber the road) a silver r34 with gold rims (p plater) then followed shortly by a black r34 with p plates again
Edited by MissR34
Went for a cruise with my wife and daughter up to mt lofty botanical gardens this morning in the GTR. :spank: Come back down via waterfall gully and then home.
On the way up
Spotted a white R31 coupe heading along main north turning right to elizabeth shopping centre. 9:30am ish
Spotted a white R33 s1 coupe on oc'onnell st turning right , in front of me 9:50am ish
Heading home
Spotted a red R32 coupe . The car was turning from Gorge rd onto lower northeast rd 1 pm ish
Spotted a r34 coupe (MissR34) on macintyre rd salis east waiting at the lights at bridge rd 1:15pm ish
Anyway had a good morning out with the GTR , wife and daughter :)
LOL dats so true... should have more better desciption of the car.
saw alot of skylines on the way home today and yesterday
saw enr 034 in seaford the other night drive right past you got snobbed haha
and saw jarreds red 33 go past me on south road also got snobbed haha
and a few silver 34's in the gully
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
