  • Replies 7.5k
Posted Images
lol probably.............im just driving and saw the tail lights and im like ohhh a blue r34...........must catch up :) too my surprise it was a GTR............certaintly made up day after seeing it!
the guy wasnt afriad to give it some either..........in a 60 zone............was not doing 60 at one stage :P
Hey Fella's,
Was out last night and not sure about what time but three R33 skylines were pulled over by i think four cops. I'm not sure if i saw correct but i know one of the R33's was on a truck and it seemed like the other two were deemed to the same fate. Anyone else see this or know what happened? This was just after Cross Road/Anzac Hwy intersection towards town. My brother was behind me and reckons he saw the same thing just wondering if anyone else knew/saw this.
Also spotted alot of nice cars out last night. All forms of R31, 32, 33 & 34. Even some nice other imports.
Dan :P
spotted helso. went to wave but didnt come out right. spotted a white 33 heading towards ttp around 10. spotted a silver 33 near hjs ridgehaven.
that was prob me the silver 33 last nite, as i was with some mates just drivin round that area lol
Around the city area today, spotted silver stagea and a silver 32 with blue front bar (possibly Nisskid from here?) wave at both but got snubbed by both..
oh sorry, did u wave? i was just having a suss of ur car and didnt see u wave. i recognized u off here but didnt think u saw me.
sorry bout that anyways, honestly didnt see u wave :( if i did i would have chucked u one back.
Spotted: A gunmetal greay 4 dr 32 followed you down windys
me maybe? im always up and down windy's but usually notice imports if they are on there. did it have a SAU sticker on the top, or a RIP drift pig sticker?
Nah no stickers at all, I had the external gate going off the guy knew about it lol and give him the nod as i went past.
saw miss r34 near adelaide air port the other day i was in a white van with RIP DRIFT PIG stick on rear checking u out lol
i was wondering who that was :( , thought it was abit weird that a van had a RIP DRIFT PIG sticker on it :)
spotted this morning, M JAY on my way to work.
Guest
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
