  • Replies 7.5k
Posted Images
silver 34 4door. greenhill rd. with a GTR grill and badge.
sure had me fooled with all those doors.
hahahaha
thats the one that was sold from sinergy it has a 34 GTR front on it but still an RB25 NEO motor
was brought over from japan like that
kye
couple not skyline spots,
yesterday at about 3 pm spotted a silver audi R8 burbling away at the tram end of hindley street, and a black 360 just around the corner a few minutes later.
and some skyline spots.
green 31 being a bit of a tool and stoving it out back of munno para shops today at about 3, and a low black on black on black r34 cruising south on main north near bunnings at about 4.
were u in the 31?
yeah, i was stoped at the intersection turning right from montague heading nth. and saw you pull out.
by the time the light went green, i was too far to catch up.
Saw bezender on South Rd @ Darlington. I was coming out the BP and would've cought/passed you but some old fella in a Toyota Echo in front of me was waiting for an invitation to leave the servo (missed at least 3 gaps!)
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
