there is a factory R32 and R33 4door GTR made by AUTECH :P absolute porn imo
jeez that 4 door GTR look mad the + side is that there isnt many around well i havent seen one yet at least every one hasn't got one.
Edited by R334door(s2)
  • Replies 7.5k
Posted Images
Besides the obvious spottings of all the SAU members and other skyline members that went on the cruise last night
On the way home on Hindley street, silver 34 with chrome/alloy starcorp impuls and SAU sticker on rear window, bout 11:40ish pm
that was probably mine...
and its twin turbo :(
saw quite a few lines last night on the cruise
What sort of power is it putting down at the treads Cain?
You should bring it to the dyno day next weekend!!!!!! I would love to see it.
+1 come to SAU dyno day on the 19th of jan i dont think ites next weekend Andrew
next weekend im having my daughters B'day party @ hundry jacks :/:(
next weekend im having my daughters B'day party @ hundry jacks >_<>_<
no deal on the dyno day. im gonna be up @ gold coast speaking to the workshop whos gonna be turning the vq35 into a vq42 ;)
and matty... cant compete with a rolla mate.. esp with a open diff :dry: just waitn for teh diff oil to fit the new ATS carbon diff and ATS twin plate.
and power is ment to be around 300 @ wheels @ 9psi, but its a na engine that has done 20,000km and has run up to 14psi on a 10.3:1 compresison ratio.
also spotted on grange road, a shittly red mirage with flames airbrushed on the front following a red vr commie then it saw my car and floored it now looks like the red vr now has flames on the rear :D:D:D
Edited by Cain
saturday i saw BAD R33 at ttp and looked mighty nice
and then saturday night saw 3 34's on a little cruise down semaphore espi and bloody hell they where mint as!
there was a light blue black n a white one cant remember if they had plates.
spotted that black range rover down the bay, plates Mazerik (i think) with huge 20's or 22's and two cop bikes pulling it over and defected.
pretty dumb doing it in the middle of the road and slowing down traffic :)
He is a person part of a "pushie" club and is rollin" on 24"s.
Is a very nuts car and he is also a very nutz person.
Isn't the first time he has been defected.
As far as i know its just wheels and exhaust that is ilegal on his range rover
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
