The BOND Aston Martin I saw was at night. It looked black from what I remember so yes close enough to British Racing Green given the lighting conditions.
Its a new Astron Martin, No idea on the model but it looks bloody awesome, so damn agressive with that huge arsed grill that looks as if it will 'eat your children' :w00t:
lol sorry on the last comment I was watching a tv show the other night where it had Mike Tyson saying the quote.. lol what an idiot.
  • Replies 7.5k
Posted Images
Saw a white 32 today on south rd at St Marys had an aftermarket hood with bonnet catches, looked and sounded nice.
the "Bond" aston martin is a convertable and was a light green. we get lots of nice cars into our chrysler yard - we had one customer with a 2004 turbo 911. couldn't believe he let me drive it (not out on the roads though :P ) not bad the first Turbo car i drove
spotted a black 180sx on fullarton rd at about 5pm turning onto parade, looked very nice n so did the chick driving it
then saw a red lambourgini in some carpark on fullarton rd after the roundabout.
then at maccas enfield saw a blue 34 gtr, looked awsome...love the electric blue...i want 1 as my next car.
hahaha saw you belting up after me from a distance to catch me Vange - damn your car looks nice! :(
Spotted MXTCY without his car in Frome Road this arvo :) - good to catch up mate
ok it must be me. since im not driving my 'line lately or more speficially today, i saw a whole heap. black 33 4dr with chromies gunning it up grand junction rd this morning. white 33 which i though was vange's along side me up parafield garden's area. also spotted an old couple in a black 32 coupe in the same area. isnt that always the case, when you dont drive, you see heaps of your's and similar around. also saw a black vanquish on main north rd.
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
