  • Replies 7.5k
Posted Images
Hostile when i waved i nearly hit the car in front of me. I didn't notice it stop, thank god for good brakes. I think i need to use that inside lane a s you always come from nowhere and dissapear into the distance while i never seem to move >_<
Yep for sure... the inside lane is always movin well cept for buses!! I always stay inside and change after the split for Ayliffes rd. Only a few km from there to work for me!
ok who was the fool who decided to fishtail it out of bp servo at pooraka. i was driving past there this morning to work, he must have seen me and wanted to prove a point. roads were wet at the time, he exited the servo driving on the limiter, i could hear it bouncing off the rev lim. seriously, its ppl like YOU who get us targeted. was a marron r33, wasnt you was it redgtst?? raises eyebrow*
WTF why does every one think that as soon as a Maroon car does a chirpy or something that it is automatically me!!!! Thr fricking cops do it tooo, one guy said he recognised my car and i had never even frickin seen the dick b4.
As for being at Pooraka WTF i would not be seen dead out there! my ride would get stolen in Boganville.
Hmmmmm -SKYLINE-?????
hmmm :) yep that was me!!! i nailed it in second until i noticed that there was water on the road from the sprinkler system......... damn council..... watering grass at 10pm at night!!!
Spotted Marron R33, with unpainted front bar, turning right into Grand Junction Rd from Pt Wakefield Rd south-bound.
Spotted (drove behind him) Black R32 with BN/Vertex kit heading north up Main North @ cnr of Diagonal.
was @ bosotworx today having timing belt done and a dyno tune after that tony had to put my front tailshaft back in and he jacked it right up on the troley jack and he said that how u want it launhing @ the drags fron wheel in the air :whistling: i thought it looked a bit kool to i got my camera and took a photo ... but i accidently had the camera set wron and it came out better than i expected :laugh:
oh enough to bring the front wheels off the ground :whistling:
on a 3rd run he got 175rwkw and stopped short cause it was leaning out
i also got a leak on the plenum so need a new gsaket and need to find a air leak shaun said u only loose about 5kw through the transfer case
oh first run was 140 rwkw (thats how sick it was)
and he said it looks like the guy that got it turbo'ed didnt just wack a turbo on the DE motor that he put a DET engine in so i can prolly run 14psi when i get the rest sorted
Edited by Madaz
Ahhhh sweet, so a new fuel pump for you then???
Guest
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
