  • Replies 7.5k
Posted Images
black R32 GTR with bronzed/gold mags, newish 'zaust, fats, and a huge fmic (edit: on sthn expressway)
very sexy.
funny thing is, the driver KNEW what my Stagea was and gave me a wave - cheerio matey! :cheers:
Im likeing the pumped R32 gtr shape more than a R33, which is surprising seeing Ive lusted after R33's since the early 90's.
Edited by Tangles
very sexy.
funny thing is, the driver KNEW what my Stagea was and gave me a wave - cheerio matey! :dry:
The driver knew who you were as well Tangles. I see your Stagea quite often on the Expressway but I'm usually in my Peugeot so you wouldn't notice me. ;)
Edited by writeoff
Guest
