  • Replies 7.5k
Posted Images
Spotted a nice grey R33 on Port Wakefield Road last Saturday (about 2.30 pm)- number plate YTRYME. Lol...... Was thinking of trying but I was driving with a bunch of girls sleeping at the back of my car. Anyway, nice boost gauge at the pillar.
Edited by bixby
you drive with a bunch of girls in the back seat regularly?
I dont drive "with"... just drive :wub:
hahaha - anyway, spotted non-skylines..... a Toyota Chaser V sedan (now THATS a realman's camry!), and chatted to a 55yrold in a silver 180sx series 2 with 3-spoke mags, full zaust, very nice and subtle bodykit that accentated the lines of the coupe, etc. Nicest S2 180sx Ive ever seen. Had a laugh with him when I suggested he'd be more suited to the Stag ! cheeky :happy:
whats in it? i see it around blackwood all the time
cheers Paul.
u do... :O
u must happen to see it on the rare days i've had it on the road recently. Blowing pintara 25 spline diff/axles etc.
As Patrcik said ^^ ca18det (since it's a pintara, straight bolt in replacement from ca20), fmic, bleed valve & now spool. :D
yeah has a turbo back exhaust - stock size lmao. 180 dump & front pipe, then from cat back is custom made 2 1/4 to fit up to a 31..will go 3" one day. atm just cat in it, no resonator etc. :D
i work at blackwood tyrepower lol hence y i'm in blackwood too :) come in say hi if ya want anyday
an yeah - 120 atw in pretty on sotck boost (8 psi) with just fmic. lot more in her yet once i get shit sorted. :D
Edited by Tylthidras
Blackwood tyrepower hey.. :)
Can you do us SAU dudes a good deal? :O
I recently priced up 2 tyres but u were too expensive compared to Typrepower in the City; they did 2 x Toyo TEO Plus for $150 each. Quite impressed with the tyre over all, and soon require another 2. I am 5 mins from blackwood so I would prefer to drive 5mins vs 20 odd to the city.
u do... :/
As Patrcik said ^^ ca18det (since it's a pintara, straight bolt in replacement from ca20), fmic, bleed valve & now spool. :)
yeah has a turbo back exhaust - stock size lmao. 180 dump & front pipe, then from cat back is custom made 2 1/4 to fit up to a 31..will go 3" one day. atm just cat in it, no resonator etc. :)
i work at blackwood tyrepower lol hence y i'm in blackwood too :mad: come in say hi if ya want anyday
an yeah - 120 atw in pretty on sotck boost (8 psi) with just fmic. lot more in her yet once i get shit sorted. ;)
lol looks like a few people from blackwood way
yeah i've only seen you between tyrepower and foodland everytime i've seen ya lol during working hours so prob explains why i havent seen ya around any other times, i just saw your car and could hear that nice turbo growl and thought it was a 31 but still good car i like it :/
Paul.
Edited by paulmac
whoah..got replies??
don't ask me to get prices etc..asknig darryl for a price for someone else is useless he forgets it too quick.
8370-2195 is best way :lol:
btw paulmac - it IS a 31. PJR31 is the coding on the id plate. 31 pintara's & skylines share same chassis/shell/suspension/brakes/diff housing just diff driveline mechanical parts. ;)
yeah..she's fixed now whip - spool's noisy as hell due to us just jamming various shims in to keep it tight lol.. still got heaps of problems, but..she goes ;)
Guest
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
