Hi all.
Just gave my 93 R33 a run at full throttle from about 60 kmph and it started "popping"
93 R33 gts25t
Only mod is turbo back full exhaust .
Standard boost, no pod.
The popping sounds the same as when it changes gear under heavy acceleration. It started around 5-6000 rpm and lost all power while it was happening.
Could it be?
A, fuel cut.
B, Detonation.
C, Faulty wast gate / Std Bov
I would love some opinions and to hear from anyone who has had this issue and fixed it.
Thanks all.
Hi all.
93 R33 gts25t
Could it be?
A, fuel cut.
B, Detonation.
Thanks all.
Also it didnt happen anywhere near as much if I accelerated slowly to full throttle still did a couple of pops but held its power.
Yup you got it. Exactly the same.
Ill start working on the electrical side as soon as i have done the fuel pump.
I changed the filter and it helped a little.
Its going to go something like this,
Fuel Pump, injectors and the things that they include..
then ignition side coil pack, leads plugs.
Im not looking to make it a rocket ship it will just be nice to have it running at full capacity.. (foot to floor no issues)
Check your FPR, pull the vac line off it and have a sniff.. If it smells like fuel, then it's a faulty FPR.
I had the same problem as you, but my issue was contaminated fuel..
Could also be a faulty pump.
By the way, do you have a larger pump ? Say a 040 ? If so, they hate 1/4 tanks of fuel lol (well mine does anyway) and it surges on boost..
Firstly im going to get the std pump to 12 v so its running at full pressure and see if that makes a difference. After that ill fit the 040 as the DIY topic explains.
I take it "FPR" is Fuel Pump Return line?or something to that description?? The one that runs from the engine back to the tank past the filter??
  • 3 weeks later...
had similar problem after fitting 3" hi flow cat. changed plugs to iridium and reduced gap slightly 0.9 mm i think, smaller gap better when combustion pressures are higher as fuel harder to ignite. gave coil packs a good clean as there was carbon around them. ran fine then. drew
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
