So I need some fuel system parts. Not much going on here in Canada or the US as far as I can find.
Torques U.K (ebay shop) sells what I'm after but I can't find reliable reviews. Are their parts really comparable to Aeroquip/earls and are their pumps legit Bosch 044s? Thanks guys.
Setup is overkill for 600whp but our tuners suck as does our fuel lol need to go rich.
http://stores.ebay.co.uk/Torques-U-K/_i.html?_fsub=1978723012
They would have everything but a cooler fo me...
Edited by NismoSTune
Another option is a locally (well, to us anyway) and very trusted company "Motorsport Connections" in Seven Hills in Sydney. http://www.mscn.com.au/Scripts/prodList.asp
Just an option for you as these guys have heaps of good reviews so if you dont use ebay and need a back up it's a great place to start.
Ah good stuff. They seem to have what I'm after but can't seem to find what make of hose and fittings they use. I currently have earls lines and need the Teflon lines for the trunk only so it all has to fr snug.
Can't seem to find many -8 fittings for earls -8 Teflon lines...
On that note, maybe someone can confirm what I'm thinking here. I've done some searching but didnt come up with much. My car is modded a fair bit but the fuel worries me...
So, for 650whp (so I don't have to upgrade a 3rd time when I change the turbo down the road), will twin -6An feeds (out of twin 044s/ 3L swirl pot) and -8 return be ok for flow? Using HKS fuel rail and ID 1000cc injectors with tomei lift pump.
Would I need a -10 return?
Back on topic, anyone recommend a good fuel cooler for the -8 or -10 return? Checking out setrab for a cooler.
Our tuners around here get us into the low 10 to high 9:1 afr (on 94 pump) at wot, so my fuel is taxed haha
I ordered teflon fuel lines from Torques UK after my locally supplied teflon hoses leaked continuously. His ones have been fine for over a year running e85, never leaked once. I run twin Walbro's, twin -6 lines with a single -6 return and fuel pressures are fine.
Make sure you always match the fittings with the same brand of hose, eg. if you have Earls lines get Earls fittings.
I need to look into a fuel cooler myself if anyone has information on them.
Ah thanks for the feedback on torques. So when you say locally, what shop or make of hose was that (you can pm if it'll insult someone on a public forum...)
As for the fittings, I plan on using the hose ends sold with the hose but will attempt to transition to my earls front lines with unions....... Might have us O ringed -an threads...
My that's a small return. When you idle or cruise, doesn't 99% of the fuel return? Those pumps should be overkill on a single -6 (return) no?
PM'd
If you look at the hole in the bottom of the reg you will realise the -6 line is plenty but you can use -8 if you're worried. Like I said I have no issues with my setup.
