33 gtst - clutch and full exhaust (bellmouth)
Had issues for a while when I fill up tank with fuel and start the car it won't idle correctly and hunts (sometimes stalls)
This issue I was always a bit whatever about it. Hit the throttle and she settles ok.
Major concern is:
I have had a very intermittent issue where the exhaust will pop when I decelerate with no throttle and then touch the throttle it will pop no matter how many times I go on an off throttle. Sometimes it will get so bad it will pop whilst decelerating down revs without touching the throttle.
Through the revs doesn't miss a beat.
Did it with 2 different motors in it. (blew motor) Only things that remained on change of engine was afm, tps, coils and loom. (fuel pump of course)
Cas, plugs, fpr, injectors all changed.
I got consult to find O2 sensor sitting at .3 when cold then when at temp sits around .1-.2V. Had a spare sitting around so tried that and it just read 0.0-0.15V. So I Bought O2 sensor and found readings Fluctuated from .28-.80V. Which a mates car also did. Got better fuel consumption of course.
Car still popped intermittently.
Tested for vac leak and all good.
Tested tps voltage and all good.
Also I originally had exhaust studs snapped so gathered that would cause popping. Changed all studs and gasket. Still popped intermittently.
It was very intermittent so hard to diagnose but of course now I am in QLD on holidays it is doing it a lot more then normal.
I have found that when I'm low on fuel it doesn't pop at all no matter how much I cruise or thrash it. I pull into servo and put fuel in and I pull out to check if it pops and it does.
So I am thinking fuel pump but why or can u guys think of something else?
Sorry for massive read but wanted to give as much info as possible.
I also understand if u all are not in the mood to think as it is Easter and u may be drunk or hungover.
https://www.sau.com.au/forums/topic/397196-exhaust-popping-on-decel-bad/
Also check tps setting.
Did u keep the charcoal canister or remove it? If u removed it wat did u do with the lines? I had a mate route his breather line to the inlet manifold and wondered why it was running rich on decel and accell
Stock bov not blocked.
Exhaust wrap isn't needed for flames lol. It's stock and people think its off tap cause it blows flames.
Charcoal canister lines were put on as they were but will gO over them in the morning.
Checked it couple times as that's what everyone thought it would be and didn't believe I checked it right. It is set at .43v and reads normal on consult when issue is happening.
I'm going to get stuck into it now and see how I go.
One way to check whether or not its the TPS is to turn the ignition off whilst on decel and see if it makes any difference. If everythings working as it should it shouldn't make any difference. Just make sure the motors hot first
Yea that's still the same with ignition off.
I have vented charcoal canister to Atmosphere and it hasn't popped and carried on today.
Will hook canister back up tonight and see if it pops (of it does) then i will undo it to see if it fixs it.
Also found fuel filler fitting loose which is why fuel leaked last DECA.
Just did manifold gasket as I had 8 snapped studs lol. All new genuine parts. Reused gasket to exhaust which was fine.
When it was popping I thought this was due to fix it for sure but didn't :(
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
