Hey fellow Stagea owners,
I have seemed to have encountered some problems with my Hicas sometime back, Only running the diagnostics last night i believe the fault codes which were interpreted by the flashing light were 1,4 and 5.
1-HICAS solenoid right hand
4-Power steering solenoid
5-Vehicle speed sensor
My question was where are all sensors/solenoids located, I believe the 5th fault code the vehicle speed sensor is located inside the dash cluster its self so that isn't a problem for me. I'm just stuck as to where the other 2 may be located. If anyone could please shed some light onto these problems i have encountered that would be very helpful.
Best regards and looking forward to your responses Chris.
https://www.sau.com.au/forums/topic/397198-hicas-diagnostic-fault-code/
check ur rear wheel speed sensors one might be playing up. i would be guessing the hicas solenoid would be on the rear craddle at the actual pump. power steering dont know about. research into it more.
So your assuming the actual Hicas solenoid would be located on the actual Hicas unit it's self?
Rear wheel speed sensor should be fine it was just the 3 fault codes which i encountered for some unknown reason but seems like whenever the right rear wheel goes over a small bump/ditch the back end seems very floaty and try's to correct steering for some reason.
  • 11 months later...
Videos of my error code are as follows, A bit unsure of the error codes I'm getting could someone please clarify for me please?
Hi Chris................old thread I know but I am curious as to whether these codes were cleared & if so what was the cure? I now have similar problem after dodgy wheel alignment. :)
The below is for R33 Skyline (1994 ~ 1999) & I guess they will do for C34 Stagea.
Codes are; 22 = Steering angle sensor not present.
23 = Steering angle sensor neutral or not present.
Apologies if this question has been answered elsewhere.
GW
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
