Hey fellow Stagea owners,
I have seemed to have encountered some problems with my Hicas sometime back, Only running the diagnostics last night i believe the fault codes which were interpreted by the flashing light were 1,4 and 5.
1-HICAS solenoid right hand
4-Power steering solenoid
5-Vehicle speed sensor
My question was where are all sensors/solenoids located, I believe the 5th fault code the vehicle speed sensor is located inside the dash cluster its self so that isn't a problem for me. I'm just stuck as to where the other 2 may be located. If anyone could please shed some light onto these problems i have encountered that would be very helpful.
Best regards and looking forward to your responses Chris.
https://www.sau.com.au/forums/topic/397198-hicas-diagnostic-fault-code/
check ur rear wheel speed sensors one might be playing up. i would be guessing the hicas solenoid would be on the rear craddle at the actual pump. power steering dont know about. research into it more.
So your assuming the actual Hicas solenoid would be located on the actual Hicas unit it's self?
Rear wheel speed sensor should be fine it was just the 3 fault codes which i encountered for some unknown reason but seems like whenever the right rear wheel goes over a small bump/ditch the back end seems very floaty and try's to correct steering for some reason.
  • 11 months later...
Videos of my error code are as follows, A bit unsure of the error codes I'm getting could someone please clarify for me please?
Hi Chris................old thread I know but I am curious as to whether these codes were cleared & if so what was the cure? I now have similar problem after dodgy wheel alignment. :)
The below is for R33 Skyline (1994 ~ 1999) & I guess they will do for C34 Stagea.
Codes are; 22 = Steering angle sensor not present.
23 = Steering angle sensor neutral or not present.
Apologies if this question has been answered elsewhere.
GW
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
