Stolen R33 Gts25-T
hks33
 Share
Hey that sux i had my silver 4 door r33 stolen 3 weeks ago from unley. cops woke me up monday morning at 5am saying they had just been chasing it. Havnt found it yet but it has been chased since if you guys could also keep a lookout for this would be great i stupidly had no insurance yet. Rego was BB464X
http://i1078.photobucket.com/albums/w483/malpaz/2012-03-09_17-47-22_284.jpg http://i1078.photobucket.com/albums/w483/malpaz/2012-03-09_17-43-55_922.jpg
2012-03-09_17-47-22_284.jpg[/img]
2012-03-09_17-43-55_922.jpg[/img]
Hey Chris they rung me about a 4 door they pulled over ring the sturt police station mate. They pulled a 4 door over and it had 89 r32 skyline plates on it silver with front mount. Head unit and sub where gone. It had been de winged with duck tape.
Edited by 95godz
I rang sturt but they knew nothing about it. did they say what area it was pulled over and what day at all?
Any other info?
They also told me if they cant link the car then they dont take it
Any info would be much appreciated.
Thanks
Sorry about late reply had no internet...
It had no vin or id plates on the car. They just asked me to come down to the sturt police station to inspect the car. I said i wasnt able to as i have no other car. But the cop was from sturt police station and said thats what was going on with that car for inspection as it had wrong number plates on the car. Plus no id badges. Sorry thats all i got on the phone from the cop.
Thanks for the reply, I called them again and the person I spoke to this time had a look but could not see it so she asked a traffic cop and apparently there is one out there and they will get back to me when he gets back to the station.
Ive got my fingers crossed, thanks again.
Have you found your car yet?
No problem mate hope it helped.
No mine hasnt been found or spotted. So pretty unlucky.. its in the claims department for just car now. Only company that would provide me with cover as im 19 years old.
Hope all works out for you mate.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
