Hi guys, I have just recently had a power fc and tune done on my r34 gtt the following mods are:
-FMIC
-FULL EXHAUST
-POWER FC
-BOV -PLUMBBACK
-Walbro Fuel Pump
So whilst driving and boosting all is ok, whilst coming to a stop and putting into reverse or just idling the revs of the car go from 900-1200 than back down than back up again, it has only happened since the tune has been done so obviously something to do that. The fuel pump and fuel filter was replaced, new penrite fully synthetic oil + filter , major service has been completed, aluminium radiator, water pump. So if anyone can tell me their suggestions that would be great thanks.
Edited by Godzilla34
https://www.sau.com.au/forums/topic/397205-er34-power-fc-idle-issue/
To be honest with you I am not to sure, i took it to a reputable tuner which has a good rep of installing power fc, it only does it for a few seconds and than it clears up and is all good again, but i never had this problem with the factory ecu i am not sure if it is a problem just thought it do a quick report and see what people had to say.
hmm sounds like u have a problem with ur ecu i can lend u mine in trade for urs and see how it goes may fix ur problem dw i wont charge u for it either
haha i dont think so. ill give the tuner a call on tuesday and see what they have to say.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
