Hey Guys,
I want to Try put a Series 2 Manual ECU in my car to see if it changes anything.
Car was auto but changed to manual in Japan.
It has always popped and chugged below 2k rpm downhill or slowing up since I bought it.
Have read somewhere that being an Auto ECU can do this.
If anyone has 1 to sell or wants to Swap for a Series 1 Manual ECU (which I also have).
Let me know.
Cheers.
Rob.
http://www.skylinesaustralia.com/forums/topic/397233-wanted-r33-gts-t-s2-manual-ecu/
Linkage to Wanted Post ^^^
https://www.sau.com.au/forums/topic/397236-wtb-r33-gts-t-series-2-manual-ecu/
  • 3 weeks later...
So I managed to get one and yes twas from Ebay. Praps a bit on the exxy side but, what do you know? My baby no longer bubbles, pops and farts when pulling up or rolling downhill. It used to have a pop if I kicked the throttle to rev match when downshifting and it also used to have a small backfire pop when changing up a gear which no longer happens either. Does anyone know if I should check/adjust the timing after changing ECU? It was a stock auto ECU and now is stock manual ECU. Any thoughts / opinions appreciated.
Cheers.
Rob.
*Edit. It'll be interesting to see if my fuel economy changes now.
Edited by Not a Pulsar
Cheers.
Rob.
Wouldve been popping and farting due to the auto ecu's not using overrun fuel cut
so you will pick up economy because you wont be using fuel on decel anymore :)
check timing to be safe, but i doubt it will have changed (unless the autos run different timing at idle)
  • 4 months later...
