  • Replies 127
Posted Images
thats sweet matt!
finally knocked together a frame for one of my light painted pics. they looked too dark printed out so i thought they should be displayed the way they were taken, with LED's.
Freaking awesome.
I want one.
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6313697
Here's mine from Friday night. Not the best, but I spent very little time setting up for it, and it was more of an experiment seeing if I could use the LED light on the front of my new Canon 320EX the way I wanted to.
IMG_5225-EditWeb by GoldZilla, on Flickr
IMG_5218-EditWeb by GoldZilla, on Flickr
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6316907
i like this one Nick. lighting is nice and smooth.
im going to be doing some light painting on a car and graff wall this weekend. the graff wall i probably wont have a problem with, but the car is making me a little nervous, lol. i reckon i need to work on a diffuser for my light stick. otherwise i'll be spending a heap of time trying different distances from the car and speeds that i walk past.will be interesting to see if i can pull it off.
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6317002
some great shots in here guys, Sidd with the wedding and landscape stuff and matt with the random freaking everything stuff but always making it look magazine cover quality.
was that mazda shoot for a job? congrats with the wedding by the way, i remember seeing a tree like that recently in mascot with enough room for some carving, if jay doesnt do the one in adelaide i will have to get in first for brownie points!
also i did the same thing as a few in here and forgot what month it is...heres what i posted in the march thread
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6320334
oh and jay love the idea of having one of those neon lit graff pieces on my wall, how much do you think you will be charging? how will it be powered?
also i know you love bikes too so couldnt help wondering if you could combine the two into something like this?
genius-or-stupid-22.jpg?w=500&h=373
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6320349
or this...
i need to get out a bit earlier tonight tho so there is more ambient light around. this is just with the gopro also till i can organise a mount for the G12 and get some slow shutter happening
as for the 'neon' graff pics. cant really sell them unless the original artists are ok with it and so far none are getting back to me.
Edited by Jay019
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6320492
lol what a spin out that you just happening to be doing the neon bike stuff at the same time, looks awesome on the wheel but a little xmas light esque on the frame with it just wrapped around it.
as for the graf artists, lol just treat them like the aboriginal artists up north and 'buy' their stuff and onsell it with a 500% mark up, profit!
https://www.sau.com.au/forums/topic/397261-april/page/2/#findComment-6320826
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
