Hi guys,
I wondered if anybody had an opinion on the best ignition setup for an RB25DET neo currently running circa 500hp but I'm about to start pushing for 650 at the wheels. At the moment I'm running standard coil packs, 8 grade plugs. It seems to be blowing out the spark in 5th gear at full boost (1.4 bar on a GT3076r)
Splitfires are an obvious choice, but what is everybody else running?
Cheers
Chris
https://www.sau.com.au/forums/topic/397299-best-rb25-neo-ignition-setup/
Have a search on ebay.au - there were some brand new OEM nissan coils going for the same price or less than Splitfires.
I wouldnt use these ebay nissan coils. Had a customer use
Some. Was going good till we got to 18psi and one of the coils split in half.
They had nissan logo's and looked genuine but didnt last a dyno session
grab a set of falcon coils in wasted spark
these are cheap and better then AU packs. need 3 of them
http://www.msdignition.com/Products/Coils/Stock_Replacement/8224_-_GM_Coil_Pack,_2_Tower_Style.aspx
search the part number on ebay
Both these need ignitors
best off with LS1 coils if you dont want to use splitfires etc
Are you sure that turbo is capable of pushing that much HP at the wheels?
It's only meant to be able to push 550hp at the flywheel on paper.
This is what I'm wondering.
If he is not upgrading turbo, then Splitfires will more than handle the task for a GT3076 as they are only ever going to push 300rwkw (400rwhp) on PUMP.
Hell Splitfires will do 400rwkw (545rwhp) as many have before. Well beyond what a GT3076 will ever make.
But... To go to 485rwkw (650rwhp), you'd be putting a very sizeable turbo on there, so big you would not be even mentioning anything based on stock ignition at that level.
The turbo is currently running 500hp at 1.4 bar. I'll wind this up as far as we can go then swap it out for a new GTX series Garrett or BW equivalent.
Say I was shooting for 600 rwhp, what do you recommend in terms of:
-plugs
-coil packs
-leads?
Thanks
Chris
500hp or 500rwhp?
There is no way a GT3076 will make 500rwhp (in Aus terms). So 600rwhp is most certainly out of the question.
600rwhp is not outside the Splitfire possibilities, the upper end of it though realistically.
Given you'll need at least a GTX35, and easily 25psi+ to get there and given that you'll need good spark.
What ECU are you using?
As far as an inductive ignition system goes the ls2 coils are very good and cheap too - they are not obviously not coil on plug though. The other option is the ford xr6t coils which are also very good and cheap. I've run 1mm plug gap with a 2jz and 2.3bar boost with the xr6t coils.
500hp or 500rwhp?
The engine is (was, as it's currently on it's way out of the car) running 498.9 fwhp, mapped on a Link G4 plug and play with a 5 bar map sensor - tested on a Dyno Dynamics rig. I set the atmospherics myself and placed the IAT sensor, so i know it's right. The GT3076R won't push 500rwhp, you're right. But as i said in my previous post, i'm currently on the journey for 600rwhp and need to upgrade the ignition system anyway - so want something that's fit for purpose.
Cheers
Chris
  • 3 months later...
Hi Chris,
Can you please confirm what your definition of "fwhp". I assume you mean flywheel horsepower (bhp) and not front wheel horsepower? :D I prefer to use wheel horsepower (whp) or brake horsepower (bhp). Also you say it was measured on a Dyno Dynamics (wheel) dyno. How does the dyno calculate "fwhp" when it measures tractive effort, wheel speed and weather conditions only? Is the engine speed also measured by the dyno? Could you upload an image of your dyno printout? Pictures speak 1000 words.
Sincerely David.
Edited by japmuscle
In the UK they mostly state power at the flywheel and in HP.
This looks much bigger than RKW,
So 498.9FWHP (GOSH) might translate into a more reasonable 300 RKW (rough guestimate)
Also what do you guys mean by introducing wasted spark?
Why would using other coils change anything to the ignition pattern?
Clearly the ignition pulse for the coils remains the same ...
(just wondering)
Edited by Torques
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
