I have seen a 33 with duel tips. They were smallish(not as big as the above picture, 2 or 2.5"), came out on the same side with a slight angle (Jap style). No adjustments were made to the rear bar, and it looked oh so cool.
If you have single exhaust pipe that splits into two tips, the extra weight would be minimal, no more than stock exhaust box.
https://www.sau.com.au/forums/topic/3974-dual-exhausts/#findComment-65395
Loudness really has nothing to do with dual/single pipe, it has a lot to do with the type and size of muffler, where it is installed, and any extra resonators placed in the system. As I see it two smaller pipes with smaller diameter mufflers may give better ground clearance, but be heavier and more expensive though.
In practical terms it is always easiest to stick with whatever type of original system was on the car in the first place. Just copy it with a slightly larger diameter system. If the original system had a resonator, it was put there to stop droning or exhaust resonance at some particular speed. Copy the original system as exactly as you can, including all the original mounting points, just make it all a slightly larger diameter.
https://www.sau.com.au/forums/topic/3974-dual-exhausts/#findComment-69080
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
