....well for 2 months anyway!!
Guys & Gals,
Just a quick post to say goodbye to everyone I've met thru cruises, shows etc etc. I'm off overseas for a 2 month break from work so I'll be missing from the meetings and cruises up until early July.
Everyone I've met has been really friendly and out of all the car clubs in Vic that I've cruised with in the past, SAU has the most *cough, cough* responsible drivers.
So anyway, Al, Maximus, James, Ash, Steve - Fiona&Kyle, Nark and everyone else my wife and I have met.....keep well, keep cruising & we'll catch up in July.
cya
Ant.
https://www.sau.com.au/forums/topic/39740-this-goodbye/
Thanks for the wishes guys.
James: Added you to the postcard list ;-) .....in all seriousness I hope to hook up to SAU while O/S so I can post updates and any pics I take of o/s ricers and skylines!!
I'm headed to england 1st, then france, next stop holland, final stop italy!
https://www.sau.com.au/forums/topic/39740-this-goodbye/#findComment-810337
ant95GTR - there do not seem to vast amounts of them on the road, probably due to petrol costs and insurance otherwise I would show you. Could direct you towards some tuners, some of whom are leaning towards jap cars. Will see what I can find out. Do you have wheels when you are here? email is: [email protected]
Cheers
https://www.sau.com.au/forums/topic/39740-this-goodbye/#findComment-818247
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
