Just like to know what turbos you people have in your skylines? What do you think is the best low-mount turbo for a rb25det. I have been told the best for a street application would be the HKS GT2535. What are your oppinions? Does this turbo bolt straight on, if not what do i have to do to get it in? Looking forward to your reply's. Thanks!!!
https://www.sau.com.au/forums/topic/39741-aftermarket-turbos/
hrmm, i think either one is sufficient for the amount of power you want to make... i would consult a turbo specialist on what the best turbo set up for your price range is.
i am just talking from experience with my friends Hiflowed T3, that worked a treat.
Hopefully someone with a 2535 will comment on that turbo and its advantages! =)
I have an HKS 2535. Just got it put on. Had fuelling problems when i went to the dyno so couldn't wind past 7psi but was getting 180rwkw at that boost level. Have just received my adjustable fuel pressure regulator and expecting a Z32 AFM and will post results when i get them. I have wound the boost up to 1.1 bar and it hits that by 3,300 rpm and pulls very nicely indeed. I hit boost cut at 1.15 bar at about 4,000rpm the other day which is my airflow meter maxing out at 5v which on an R33 happens about 220rwkw so this turbo should easily see you to your desired power level.
As for installation, it bolts straight on to your exhaust manifold, dump pipe, AFM pipe and with the supplied elbow, to your intercooler pipe too. I got the GT Sports Turbine Kit which came with braided hose for the oil line and new replacement piping for the water lines. Hope that helps.
oh, you wanted mods too...
When I finally get my power run again I will have:
Trust FMIC, Z32 AFM, Bosch 910 fuel pump, Nismo adjustable FPR, full exhaust, Trust Ex Cam Gear, S-AFCII, Blitz EBC and rebuilt engine with forged pistons.
you should be fine, so long as your engine has sufficient compression and when your running 12psi it isnt leaning out/detonating etc...
invest in a dyno tune from somewhere that is renouned for tuning properly.
Reliability is the key!
Nothing sh1ts me more than when someone tells me they have 200+ rwkw and have their standard injectors maxed out etc etc. Thats just not cricket.
Exactly!!! I will have a power FC so as far as that goes it can be tuned accordingly. I hate when i go to shops (no names) and the guys there tell me that i can get easily 270 rwkw from my standard engine without problems. I think that is total crap! Can do it but it will probably last about 2 months or so, then the problems will arise. Anyone here have that kind of power with standard internals? Just like to hear about it?
i am attempting to put on a t3/t4-super t 70 on mine all i can say it is ***ing huge 1700 it cost brand newcop a look at the specs.....shaft and wheel trim64.5 mm -compressor wheel super70 60.5mm -turbine housinga/r84.-compressor housinga/rratio.70... supposed to be capable of 650 hp can any one who knows what they are doing tell me the go and what mods/ lag ect i will expect
Your engine will last with 270rwkw on standard internals, I know of several cars that have lasted over 6mths each after being very heavily murdered with much more than 270rwkw. It all depends on your tune :rant:
Guest INASNT
Your engine will last with 270rwkw on standard internals, I know of several cars that have lasted over 6mths each after being very heavily murdered with much more than 270rwkw. It all depends on your tune :)
It depends on the tune and how u drive. If u drive like a tool all the time at full throttle then ur engine wont live long.
Mine has lived with over 300rwkw high boost and 260rwkw low boost for about 2 months now without any problems.
Fuel seems to be the problem IMHO. Alot of people try and stretch the stock injectors to places they just werent meant to go. All that I know of who upgrade the injectors and dont chase every last kw, have had no dramas.
Personally I wouldnt really want to chance it (well I didnt chance it). If you upgrade the injectors as you fit a bigger turbo you will be safe - with a good tune. Cheaper than a rebuild - infact cheaper than a set of forgies:)
I have over 300 in a daily driven RB25, running over 20psi no problems - stock internals. the JMS R33 had over 300rwkw with stock bottom end too, and that gets caned - still going strong.
I want to do everything properly, no short cuts. What would be the best size injectors for this application? Where do you suggest to get the car tuned at? I heard that Croydon Racing is the best but they charge an arm and a leg! I think it was like $700! Any other good places?
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
