  • 3 weeks later...
http://www.skylinesa...ad-of-username/
sorry I should have posted it straight in here, saw the sticky after I posted.
edit:
Is it possible to get the topic title as the first item in the email notification like it used to be?
Currently it is:
New Reply: DVS JEZ
when I look in my email, but that means I have to open the email to see what thread was replied to, what would be nicer is:
New Reply: "Hypergear Hiflow Service Continued.".
Is this possible to achieve? the main issue is Gmail doesn't group the emails based on topic, it just floods my inbox with an email for every single reply, if the topic is the same then it groups them all together.
Hope someone can help, this was an issue with the previous forum software many years ago but after a request someone changed it.
Thanks.
Edited by Rolls
I can't seem to log into SAU via the login with facebook button anymore, it comes up with this error..
[#1090091] An error occurred while trying to authorize this Facebook connection.
I had to log in to type this with my lurking account that I made AGESSSS ago lol.
If this error can't be resolved, please deactivate this account so I can use the e-mail to make another account under my usual name or rename this account the same name as my usual name :thumbsup:
My user is
JDMKiD__/ⓞⓞ-33
feel free to search it and maybe even put my stats or whatever but I'm not super bothered.
Thanks
-Timi
Not sure if this has been mentioned, but it wasnt listed on the first page
On attatched images to posts (maybe just with people who have a large sig) There is a line about 1/4 of the way down the top line of attatched photos and anywhere below that line I cant click on the photos. So if there is two rows of photos, I cant click on the second row of photos at all
example in this thread:
http://www.skylinesaustralia.com/forums/topic/397602-how-to-replace-a-timing-belt-202526-pics/page__pid__6312364#entry6312364
Can post a screen shot if needed
edit:
Currently it is:
New Reply: DVS JEZ
Thanks.
Anyone able to help with this? Really would appreciate it, means I miss a lot of replies in topics as I just don't check my "content I follow" very often.
Thanks again, I am enjoying the new layout though, much more stream lined.
http://www.skylinesa...64#entry6312364
using chrome (ver:19.0.1084.52 ), i get the same problem. its overlapping on the signature. once i hide the poster's sig, i am then able to click on any of the pics
Also regarding the pics attatched to posts, is there any way to get rid of the photo without pressing back on the browser? Most sites you can just click outside the photo area and it closes the photo
I'm not sure if I'm just doing it wrong or if this is the only way to get out of the photos. Not a major issue but thought I would ask anyway :)
im still not getting email notifications, is there any fix for this?
For any one else with this problem i found that you have to go into your control panel and set it up so you get email notifications again, every thing seemed to be set so no notifications will be sent.
Yep this was all I had to do.
Email notifications are working fine now.
You need to re-enable them however. Christian has created a simple guide:
http://www.skylinesaustralia.com/forums/forum-253/announcement-32-pranks-illustrated-guide-to-email-notifications/
yep that is very helpful. but there is still a problem that is a real pain:
the topic is unhelpful - the subject of the email should be changed to the topic title to allow common emails to be grouped.
Yeah I mentioned that earlier, it is quite a simple fix if someone would let me have access, I'm guessing nismoid won't though haha.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
