cancel that, new topics are fine, and always have been
PMs say "<username> started a new personal conversion with you" or "<username> has replied to a personal conversion". It would be helpful to have the title in the subject as well, eg "<username> has started/replied to a personal conversion <title>"
I am dissapoint :(
I was genuinely excited by the "new dark skin available" announcement. It was a LOT easier to hide the open window within my CAD desktop :laugh:
I am dissapoint :(
So its not just me then.
No new skin.
Sadface.
C said - Almost done guys....
I've been testing it for a couple months, there are a few problems with it that need fixing before its useable.
Ok, peeps, looks good to me.
We happy?
Dark theme is almost done too.
I've noticed a few changes today whilst I've been browsing :)
New skin is cool.
One thing I have noticed.
No longer able to tell if you have posted in a thread (it's a star on the other skin).
And kinda difficult to determine between read/unread.
Other than, very cool.
Thanks for all the hard work.
:cheers:
Looks like it might have been permissions - try again.
Works brilliantly now. Once again, love your work big guy :thumbsup:
A thousand internets be upon you, friend.
New skin is cool.
It is now a circle - not a star :)
Works the same, just takes some getting used to
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
