So before when i had "my topics" on the right hand side with all my watched topics and displaying what was new and a button to view old watched topics, How do i go about having thise feature again or will i just have to use this notification dropdown thing once its sorted out?
Regarding the no mark all items read button:
Using the default skin, doesn't work/appear on the "pulse" on either.
Browser is google chrome.
Using the full version.
It's the button that when browsing the forums with "view new content", once you've read through the new posts etc it used to be in the top right of the topics list.
what he said. buttons disappeared
Yeah. just got a new notification about your reply but had to click the previous "quoted a post you made" to get back to this thread from the notification drop-down.
Please post up a screen dump of your notification settings.
I believe it is something to do with those as mine work fine when i click the heading. As there are different settings/options i suspect it is related to this.
You'll notice there are a LOT more options now in that content section.
You can filter by a lot more choices now, filter by specific forums, specific threads you've posted it...
Even specific time ranges.
There is a "mark all as read" option at the VERY bottom of the forum. This will mark the ENTIRE board as "READ".
I believe the new way IPB does is this is such that you can now customise filter so extensively you shouldn't need to mark the entire board as read all that often.
This is deemed not to be an issue now - I will mark in the Feature thread.
Thanks.
Please read here:
http://www.skylinesaustralia.com/forums/topic/397488-follow-this-topic-resolved-1104-2100/
From the "Content I Follow" button, you can see heaps, play around with it.
Should cover it. If not post in that thread.
iPhone mobile mode
Whatever that square window ting top right is.... Dosnt do anything? What is it
How dobi get to any menus like my messages and new content etc. I assume it that window I can't click?
Also loading blackouts don't disappear
Added to the list.
Not sure if everyone is having this issue however.
Tried to Edit my Sig but it is just a heap of Code and it scares me.
Screen dump please and list full details as per the first post requirements.
Note: I've just gone into your signature, and it's showing up in HTML fine.
So you've likely got HTML functionality disabled. Time to start a new sig or enable HTML - as the only stuff that's there is put there by you. Not really sure I'll be able to help.
For some reason, it was fine when I just went back to look again. WTF???
I'm using XP and IE8 and Pulse skin.
Please go back to your old avatar. Us Puppets need our Master.
Edited by Not a Pulsar
Had switched to the "old" theme. With the new theme, it isn't a problem with the thread topic area, but the head of the page is still stuffed. Being overlain with my window tabs.
How to I upload the PrtScr image?
Using FF 11.0, on Linux. Don't see that it should matter, because it worked before the "upgrade".
Had to take a photo:
Added to the list. Not sure if everyone is having this issue however.
i haven't had this issue. iPhone using Safari browser and viewing the mobile version, when i press the "window" button on the top right i get a tiled overlay with messenger, notifications gallery, sign out etc. press it again to close the overlay.
what i have noticed is. when viewing the full version of the site on my iPhone, i press the "Use Mobile Version" link at the bottom of the site. it loads the mobile version fine but, as i said before, there is no button to change back to the full version of the site. if i want to go back to the full version i either have to clear the cookies/cache, or close Safari and remove it from the multitasking list. then open Safari back up and load SAU, the mobile version will now load with a "Full Version" button down the very bottom.
i thought it may have been a one off when i posted yesterday but it seams to do it every time i change between full and mobile versions.
Thanks. Yes clearing cookies/cache is normal when reverting back to full versions.
I do believe it was the same with the last version as well.
GH05T - I think you should do the above, and then see if SAU works fine for you. I think it'll be a phone issue rather than a SAU one
Thanks
- iPhone - When browsing via mobile on iPhone the Menu Box does not appear (right hand side). Works fine on Android. Resolved - See here if having similar issues: http://www.skylinesa...ost__p__6311151
Thanks.
Ah there it is! Cheers Ash. It'd moved more then one scroll and I got lost.
Again on my iPhone mobile mode
I don't have page numbers for threads so to get to the last page of say the Liz thread I have to skip trough up to 500 page to see the most recent post.
I only have next button so no page selection numbers
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
