Sad, I know. I'm wanting to keep my car completely stock though and for me as I dont have an exhaust - etc, you can really hear the rattles on idle and low RPM.
Ant, when it comes out and I know the specifics - you'll be the first to know. (Mates rates for sure).
I don't get it...
It's not a limited edition, and by the sound of it you drive it reasonably often - so essentially it's not worth anything extra kept standard. I think you are crazy to replace it to pay labour costs to go backwards. It's worth more in the car than out of it
But... each to their own
I was in the same situation a few years back when I had to replace my HKS Twin Plate and had no idea what to go for.
I thought out what I was going to use the car for and future plans for it.
It's my weekend car and I had no plans on running more boost, so a single extra heavy duty clutch would do me fine.
You'd figure Nissan would have engineered / designed / used a clutch that can handle a twin turbo car.
Hence an OEM clutch for a GTR should be able to handle the power of a stock car.
So I went the OEM clutch.
My knowledge was limited as to what brands where out there, but if I had known back then, an Exedy / Nismo would have been one of the top choices.
I don't get it...
True.
All true. Thanks for the advice, will rethink the plans.
I could understand if you had a OS Racing twin or something, as they are such a nasty nasty clutch to use in traffic etc. Same with a lot of other twins.
But the Nismo is awesome, best clutch money can buy for its purpose.
Who knows, in 12 months you might put an exhaust on, tune and a set of turbos - then you'll wish you had one.
Thanks for the advice mate.
You're right about the mods - I learnt from my other cars once you catch the bug its hard to stop and one thing just leads to another. Although I am aiming to keep this one stock and locked up in my garage to use as my weekend car (famous last words hey).
This afternoon I will work out how to post a video of the car on idle. Curious for some feedback.
Yep the classic gearbox getrag rattle :)
Also due to the thin viscosity, and small amount of oil used in these boxes that gets thrown up to the higher parts of the box. RPM also dictates how noisy they can be too. Mine with A/C on will be noisier, and if it is warmed up at idle revs.
Add 10 or more years of use, plus getting rid of the factory dual mass flywheel and they are a pretty noisy box as bearings slowly wear and clearances also open up.
Sometimes if I want it to be just a little quieter, I can just tap the clutch when waiting at the lights in neutral and it will be a bit quieter. I think this is due to the input shaft getting into a dead central position (talking in thousanths of an inch) and making less lash noise in general.
Some people recommend changing the input shaft bearing, or recoing box, but it really is just the way the box is as time goes on as well as using non OEM flywheels.
There are some that are noisier than others too.
Hi mate, Yeah I put Castrol Transmax Z in it last week hoping it would make a difference. No luck in that space.
Foot in the clutch is what I've been doing too. Its funny how you can put your foot in, take it out and put it in again and the noise sounds different just about every time.
+1
As Piggaz indicated, you DON'T do that...
if its a Nismo clutch!!!
If its a Nismo twin copper, it's worth $3K+ that will outlast a new single HD plate.
G-Max that N1GTR talked about in his link is $4K+ (with flywheel encased)
Hi All,
Spoke with my mechanic today.
Nismo clutch is like new, will be keeping it in the car. Apparently it was the spigot bearing which was making the noise.
Will get further details most likely on Monday when I pick up the car.
Cheers.
  • 3 weeks later...
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
