Hope this is the right area.
Was on gumtree this morning looking for skylines as usual, and there must've been a shipment of imports because there was a few skylines and evos uploaded from wangara (car shop suburb for all you non WA people)
I did find a two stock R34s which I was so happy to see. however the manual was 18k and the Auto was 11k :(
This seems way to expensive, are they overcharging? Because if I could get that auto cheap I'd just do an Auto to manual conversion with an r33 gearbox and follow an old thread I found on here :)
So what is the currrent value for auto and manual R34s (stock) that you guys think?
https://www.sau.com.au/forums/topic/397491-value-of-auto-r34-gtt/
labour isnt really a problem, dad rebuilt a few cars, I'm not afraid to get my hands dirty, and cousin owns a repair shop with a hoist. And I'm not looking to increase the value. I just hate auto's with a passion :)
ok a few things, there will be a big difference in the value of cars that are the same. you may get 2 r34's, both manual, etc that are vastly different in price. a lot of this will come down to general condition of the car. some will also come down to one owner being more eager to sell his car than the other.
as for the auto vs manual price difference, there will always be a difference in price. the 18k manual one is at the upper end of the price range. you will certainly find cheaper ones around. unless you could get the auto for a lot less than 11k i wouldn't bother doing a conversion. for starters, parts will cost you a few thousand dollars to do it properly. will still cost you a few grand to do a half arse job. then there is all the dicking around with getting the wiring sorted so that the ecu uses the right maps (most people don't do this).
i would also say the same thing about importing a car vs buying locally. don't bother importing. buy locally. that way you can personally go and inspect the car, take it for a drive and see what it's like. you can inspect the body, listen to the engine and get a general feel for what sort of condition it's in rather than just taking someone elses word for it.
you may also want to do plenty of research of running costs and maintainence costs of a turbo car before you get too far in the process. things like how expensive insurance will be (a lot for a young driver), running it on premium unleaded, regular oil changes, etc. plus the cost of fixing common problems such as failing coil packs. they aren't for everyone.
yeh I am, I dont get why there's such a huge price jump from R33s to R34s... There was a gtst R33 for $3500 on carsales in FEB that I saw.
Basic Rule:- Production Numbers of the R34 were much less than the R33 > Join the dots.
BTW, welcome to SAU
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
