Hey ppls.
After a fair few kilometers I have only good things to say about them.
I never used to be able to launch with anything more than 2500 rpm with a clutch dump and be left with anything else but wheel spin.
Also, my previous tyres would break traction in first almost as soon as I made decent boost. Yes, my old tyres were crappy.
The new Hankooks, well they are great.
Although I haven't tried any big launches as I haven't been to Calder Park yet, they seem to hook up great. I've tried some reasonable launches at about 3500 with a fairly rough dump and the damn things just bite and off you go.
With the clutch out in first, I now don't break traction until at least 5000 rpm, and by that stage, I'm having to grab second anyway, because it's less than a a split second after that I'm on the rev limiter anyway.
Pulling second sees as very breif chirp and then traction all the way.
Cornering, well it turns corners pretty well on the street. I haven't got right up it yet, as I haven't been on any twisties or a race track yet, but on my normal streets it's all good.
All in all, I can't fault them.
Maybe I might even have more luck at the next DECA day with them!!
BASS OUT
  • 2 months later...
  • Replies 68
Just bought four 235/45 17" Hankook K104s, since everyone is raving on about this particular tyre.
I havn't yet tested them in wet conditions but they seem like a very comfortable drive, and arn't noisy.
Got them from Jax, rang a few different stores and they all varied in prices! some had the tyres for $30 more!.. Got them for $169 each after some negotiations :D also did my wheel alightment front and rears.
Seems like a good tyre so far.. they are rated Y grade and have silica compound too!
  • 2 months later...
i have also ordered a pair of these hankook 104s, i think jax is the best place around me anyway to get them
i was after 215/45/17 jax quoted $180 per tyre (Jax Mosman Syd) whereas bob jane etc said this spec didnt exist in the 104s and the closest spec (40s) were $240 :P
apparently queensland jax stocks them and this is the way jax nsw have access to them but other outlets dont seem to and charge an arm and a leg
  • 4 months later...
I bought a set of hankooks k104 and here are my thoughts on them.
Replaced my old tyres which were the falken st115 with these last december
I took notes of how the k104's felt as i ran them in.
Ive done about 9000km on them in the past few months.
Fronts are the same size (225/45/17) and rears i went from 235 to 245 on the hankooks.
Used to run 34psi on the st115, now run 36 with the hankooks
Cost was around $215 for fronts and $230 for the backs (or something like that)
Straight line performance
When new and after a few 1000kms: Straight line performance kills the st115's. That includes braking and
launching. Very impressed with them in this regards. Even when brand new, tyres were substantially better in
straight lines. After a few thousand kms (3000km is the sweet spot i reckon), they were really really good.
After 9000km, theyre still good, but its a bit hard to compare now since the car has more power now (200rkrw).
Still, its safe to say that i have more grip now than when my car was on st115 with just an untuned ecu, fmic, boost and exhaust.
Turn in
When new: On turn in into corners, they do feel they have slightly less grip than the st115's.
After run in: Probably the one thing i dont like about these tyres is that on initial turn in, theyre theyre slightly
worse than the st115. Difference is small, but even in the sweet spot of the tyres (around 3000kms) they were
never really better. Still, its not so bad, cause it just understeers a bit and its very predictable.
Part of the reason could be that the sidewalls feel softer than the st115
Midcorner
When new: St115 is underated in this regards. When warm the st115's do a fine job. When theyre
cold though, they are a horrible tyre. Initially, the k104 didnt have the same levels of grip as the st115
did when they were warmed up. When both were cold, they were about the same (ie horrible)
Even though they had less grip, i still felt more confident in them because of the way they slide out. Really
progressive slide. In the st115, if the tyres let go, it lets go in a big way.
After run in: Once i got some kms into the tyre, things started to change. I reckon even 500-600kms isnt
enough to show the true charactristics of the tyre. It did improve though. Once it hit the sweet spot (3000km)
of run in, it was as good as the st115's when they were hot. Its hard to say which is better though since
i have no direct comparison, but i reckon k104's are now slightly better. You can feel the hicas do the
wierd shifting thing at the rear whereas before you couldnt really feel it in the old tyres.
Wet
Both are equal, ie not too good, but not that bad. Good enough to go faster than traffic and not bad
enough to be dangerous in the wet. Both have deep channels for the water to get pushed out.
Ride
I think the softer sidewalls of the k104 makes for a more softer ride. A trade off for less direct steering
on turn in? Anyway, its good for sydney's bumpy roads although i miss the directness of the st115's
Wear
Wear rate on these tyres are pretty good. st115's really dont last that long. After 9000km, the k104 still
look good. Performance hasnt dropped off too much either from the sweetspot. If the best grip the tyres
had were at 3000kms, i would rate them at 9000km as maybe 90-95% as good. So yeah, pretty happy about
that.
The thing that makes the k104 better overall is just the way they behave on the limit and in when theyre cold.
The grip is consistant when cold, not like the 115's where you have to be careful pretty much all the time.
If youve been dawdling along and suddenly you want grip, you can just go all out without worrying about the
tyres being cold. Also, because of the way they slide, it feels much safer to push them. If you go too fast, they
sqeal and slowly slide, but in the 115's, they sqeal and you slide in a big way before coming back to you.
So overall i like them. if the st115 were rated at 6, id rate the k104 at 7.
They grip the same, but thats all the time, not just when the tyres are warm.
They cost around the same, but the 104's lasts way longer.
For a street tyre, theyre great value for money
(geez, didnt realise it was such a massive post! hope it helps somebody i guess :( )
  • 1 year later...
Just rang up Donnellans in Box Hill, they quoted me for 255/50R16:
Front: $165/tyre
Rear: $175/tyre
Probably take car (180SX) in today or tomorrow and get them fitted. Originally they quoted me 175/185 (front/rear) but I said heaps of people are paying that for 17" - and he said it's because they sell more 17" than 16" these days, which I can see lots of truth to (looking at this tread). Then he dropped $10/each so that's cool. Currently I'm running Federals 225s rear and Simex 205s front - ew. Rears are bald as a badger. I do drive like an old granny most of the time though. :-)
I'd had a bit of trouble getting quotes out of places too. Rang up 2 Jax's and both wanted to call back (had to call their supplier), and only one did, and he said you can't get K104 in 16" 225s??? (according to their website, you certainly can). And I also rang a Beaurepairs who said they cant quote me anything until they see the car. Had to do with legalities of liabilities etc.. blah blah. I've learned to just go with the smaller places at least.
i've had these tyres (225/50/16) on my car for about 150-200kms. felt like i was driving on ice for the first 50km. even after about 200km they're already gripping better than the old maxxis tyres i had and don't spin up when on boost.
The time finally came to replace the K104s last week... 42,500km later! Pretty impressed. I could've got more km out of the fronts if I aligned more frequently. The rears... well it's a rear driven turbo :P
I've gone with Dunlop SP 3000 this time simply because I got them for $105 each :) I've only had them on for a few days and already they're feeling very nice indeed, but I suppose they would considering the Hankooks had been well and truly punished.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
